1978 - 1996 Big Bronco
High Idle Start
Old May 31, 2004 | 06:38 PM
superman0604's Avatar
superman0604
High Idle Start
When I start it, it will idle at 2,000 rpm and then slowly idle down to 1,000 rpm. If I shift while it is idling down it will die. What could be the problem.
Old Jun 1, 2004 | 12:19 AM
CLHAY's Avatar
CLHAY
Vacuum leak, TPS, IAC!
Old Jun 1, 2004 | 12:23 AM
superman0604
What is TPS and IAC?
Old Jun 1, 2004 | 12:25 AM
CLHAY's Avatar
CLHAY
Throttle position sensor
Idle air control valve
Old Jun 1, 2004 | 06:43 AM
fcarruth's Avatar
fcarruth
Check out this link. https://www.ford-trucks.com/forums/s...d.php?t=243202
Good luck,
