Steering column cab seal
Old May 14, 2019 | 01:00 AM
desperado_18_2000's Avatar
desperado_18_2000
Had to unfortunately swap the steering column out in my recently acquired 77 f100 for a spare I had out of a 74. Everything bolted and plugged in just fine save for the seal on the column where it meets the firewall.
My question is there an easy way of swapping this mount/seal out? I haven't experimented with anything yet so I'm not sure.
Definitely could use a little advice here as I'd like to get this buttoned up soon so the cab isn't exposed to potential critters for too long.
Old May 14, 2019 | 02:07 AM
Skip1970's Avatar
Skip1970
rubber? cut and install around
Old May 14, 2019 | 10:41 AM
mark a.'s Avatar
mark a.
Yep, either cut it or pull the column back out and change it.
Old May 14, 2019 | 10:53 AM
desperado_18_2000
Looks like I'll be cutting one and installing the proper one off the old column for now. The one from the 74 is fine save for this difference so that's what I'll use.
Thanks!
DoggedTired
13
Jun 24, 2024 05:16 PM
jniolon
Dec 30, 2017 09:07 PM
Idaho Highboy
30
Feb 23, 2017 05:53 PM
dmccorkle911
16
Jan 22, 2016 10:39 AM
7278ford
Oct 25, 2009 10:29 AM
