Vent window toasted?
Old May 13, 2019 | 05:09 PM
The_Scatch's Avatar
The_Scatch
What do you guys think... Attempt to clean it up and make it work.... Or replace it?
Old May 13, 2019 | 05:13 PM
kramttocs's Avatar
kramttocs
I'd pick one up at the jy.
Old May 13, 2019 | 05:20 PM
The_Scatch's Avatar
The_Scatch
That's what I'm thinking. That steel is separated I won't even be able to pull the glass out probably.
Old May 13, 2019 | 05:52 PM
kramttocs's Avatar
kramttocs
I recently picked up a couple at the jy as mine had some rust swelling also. The nice thing is that most door panels have already been removed so you just have to pull the window out of the track and remove the vent. Don't even have to take the main window out. Be careful removing the nut as the threaded flat rod tends to twist. You might want to just swap the whole unit, track and all.
Old May 13, 2019 | 08:02 PM
The_Scatch's Avatar
The_Scatch
This is exactly what happened as I took her apart. Closest junk yard I could find with a donor is about 2 hours away. It will definitely be a weekend trip
Old May 13, 2019 | 08:29 PM
kramttocs's Avatar
kramttocs
Ebay has a good looking left and right selling by pats auto (can't get eBay to give me a link on the app). The price for each is 10x the jy price but would save a 5 hour venture.
Old May 14, 2019 | 12:00 AM
BigBlue2's Avatar
BigBlue2
I repaired my wing frame by sanding out the rust and rebuilding the frame with JB weld. sanded it smooth and painted it black with rustoleum then build it up with JB weld, sand smooth and paint again. Lasted for a while but needs replacement eventually. Have you asked your local glass shop about replacements?
BB2
Old May 14, 2019 | 08:22 AM
FuzzFace2's Avatar
FuzzFace2
May want to place a WTB add.
I had to replace both of mine because of bad pivots and got them from a FTE member.
Dave - - - -
Old May 14, 2019 | 11:09 AM
The_Scatch's Avatar
The_Scatch
All great info guys. I'm definitely scrapping these. Any tips on getting the glass out? I think I should attempt to save the glass should ever the need arises to replace it... Or maybe it's not worth the effort.
Old May 14, 2019 | 12:11 PM
BigBlue2's Avatar
BigBlue2
If you have a place to store things it attracts stuff like iron to a magnet. I'm storing a lot of parts of all kinds. I know one guy on this forum that has 5 doors. A couple wing glass seems easy enough to put on the shelf.
People think I'm crazy for buying filters by the case even...so yes you will likely face scorn but laugh it off. You know what you have in your hands is genuine !
BB2
Old May 14, 2019 | 07:46 PM
whisler's Avatar
whisler
I have a set (both sides) from my '86. Where are you located. Also have a set of door glass.
bstephen33
'80-'86 FAQs (Frequently Asked Questions)
Apr 5, 2019 01:12 PM
beartracks
Jul 24, 2015 08:24 PM
gtanns
Apr 29, 2015 06:59 PM
bstephen33
Jan 20, 2011 12:07 PM
