Sponsored by: Real Truck
350 no start
Old May 11, 2019 | 01:35 PM
maxheidisib's Avatar
maxheidisib
350 no start
Hi Guys got a 2001 7.3 no start, followed usual things, cam sensor, injection pressure sensor, changed regulator seals (high pressure).
It did cough a bit with new cam sensor but nothing now. I have 1800lbs oil pressure on cranking this falls to 60 if you unplug regulator so I guess that side is fine.
unplugged injector harness definite ground on centre pin but no voltage on any injector + wires so I guess no voltage to injectors. Tack moves slightly on cranking. Thinking IDM?
Does anybody have wiring diagram for an IDM to check cables? Any hidden fuses? Don't have access to diagnostics only UK ford.
Thanks in advance
Max
Old May 14, 2019 | 03:32 PM
SteveH-CO's Avatar
SteveH-CO
Try the 7.3 forum - many more people there who can help.
Old May 15, 2019 | 01:25 AM
maxheidisib
Thanks, might have found problem injector control mod if full of water!
Max
Old May 15, 2019 | 04:37 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
That'd do it for sure.
BRay09
Mar 8, 2023 07:57 PM
MDH16
Jul 21, 2017 05:29 PM
smajr85
Jun 4, 2015 10:35 AM
12 pointer
Aug 24, 2013 09:08 AM
Hootch
Mar 4, 2013 02:28 PM
