Ford Truck Enthusiasts Forums
-   1999 to 2016 Super Duty (https://www.ford-trucks.com/forums/forum30/)
-   -   350 no start (https://www.ford-trucks.com/forums/1582882-350-no-start.html)
maxheidisib 05-11-2019 01:35 PM
350 no start
Hi Guys got a 2001 7.3 no start, followed usual things, cam sensor, injection pressure sensor, changed regulator seals (high pressure).
It did cough a bit with new cam sensor but nothing now. I have 1800lbs oil pressure on cranking this falls to 60 if you unplug regulator so I guess that side is fine.
unplugged injector harness definite ground on centre pin but no voltage on any injector + wires so I guess no voltage to injectors. Tack moves slightly on cranking. Thinking IDM?
Does anybody have wiring diagram for an IDM to check cables? Any hidden fuses? Don't have access to diagnostics only UK ford.
Thanks in advance
Max
SteveH-CO 05-14-2019 03:32 PM
Try the 7.3 forum - many more people there who can help.
maxheidisib 05-15-2019 01:25 AM
Thanks, might have found problem injector control mod if full of water!
Max
CathedralCub 05-15-2019 04:37 PM
That'd do it for sure.
