Oil cooler swap
Old May 9, 2019 | 04:37 PM
kd5zll's Avatar
kd5zll
Yeah, thats a new body. But in the past, a steel part like that, would be degreaser of choice, followed with steel wool, very fine steel wool
Old May 10, 2019 | 09:35 AM
SaintITC's Avatar
SaintITC
55 minutes from kitchen sink to installed! Nice work.
Old May 10, 2019 | 09:37 AM
kd5zll's Avatar
kd5zll
Lol, i didnt even think to look, but yeah. Biggest trouble was the front 2 bolts, probably half the time spent
Old May 10, 2019 | 10:20 AM
F250_'s Avatar
F250_
OK... it looks like a brand new unit. Maybe I missed it somewhere, but why did you replace the unit?
Old May 10, 2019 | 04:01 PM
kd5zll's Avatar
kd5zll
Because i want no questions if my oil into coolant continues, i want to know that area is as good as i can make it, so i will look elsewhere for the leak
Old May 12, 2019 | 11:42 AM
BBslider001's Avatar
BBslider001
Nice work man. Any update? You should be able to find the coolant flush procedure that Diesel Tech Ron (RIP) did on Youtube when oil gets into the coolant. I think he uses Cascade dish soap. do NOT use Dawn....you'll never get it out.
Here ya go:
Old May 12, 2019 | 11:53 AM
kd5zll's Avatar
kd5zll
Well, i got the oil, and water added, the rear coolant drain plug is frozen. I had figured swapping this would drain it sufficiently. I ran it long enough to open the thermostat, added more water. Still have light brown chocolate milk in the degas bottle. I have a cold oil level, so my next step will be to run it a day, and see if the oil drops on the stick. If it doesn't, then I'll get the coolant deep cleaned, if it does, then I'm back to hunting the source. No smoke on start up, everything is stock. Not sure if there's anywhere beyond injectors, cups, and head gasket, for oil crossing into coolant
FL SuperDuty
Dec 22, 2017 10:29 AM
mini_blaine
Jul 15, 2017 07:45 AM
jpcjguy
May 31, 2017 09:55 AM
ajsemtb
Apr 5, 2017 06:46 PM
dbcrowell
Nov 1, 2011 04:58 PM
