1951 239 flat head valves
Old May 5, 2019 | 10:35 PM
Old51f3's Avatar
Old51f3
When I opened up my valve covers noticed one valve was missing the retainer clip And with over time the valve got pushed around and got bent.
Its an an origional ford valve. I’m trying To replace the one valve but come across 2 different option. An exhaust valve and and Intake valve.
Which one should I use. I think the ones on the truck are all the same .
Old May 5, 2019 | 11:14 PM
Mixer man's Avatar
Mixer man
Exhaust and intake valves are different. Which valve is bent? Were you able to find the missing keepers?
Old May 6, 2019 | 07:12 AM
Old51f3's Avatar
Old51f3
It is the intake valve
I did find pieces of the guide keeper. And one valve keeper. I’ve looked in the block and took a magnet to all the small fragments of metal in the block and did not find the missing valve keeper. This valve took quite a beating. The valve has even been forced thru the valve guide. See pictures attached
Old May 6, 2019 | 10:16 AM
52 Merc's Avatar
52 Merc
If the empty valve hole in your block is the valve that's damaged, it's an exhaust, not an intake valve. Intakes are in line with the ports above. Exhausts have ports that run around the cylinders at the middle and ends of the block, and terminate out the side of the block.
Old May 6, 2019 | 11:37 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Be aware, a '51 engine should have "Rotomatic " valves, which are different length than the valves used before late '50. You can spot the difference quickly by looking at the spring retainers. Many of the rotomatics have been replaced with the earlier style during rebuilds. Can you post a picture of yours? Below is the manual's p/n's for both types, and a picture of the two styles side-by-side.
Old May 6, 2019 | 11:55 AM
Old51f3's Avatar
Old51f3
Mine looks like to Be non rotomatic
Old May 6, 2019 | 01:36 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Correct, are the rest also non-rotomatic? Make sure you buy the correct replacement. Does your engine have hardened valve seats? It appears to. On the back of the block, next to the oil pump drive gear cover, is there a "0BA" or "1BA" cast into the block? (see below)
Old May 6, 2019 | 04:50 PM
Old51f3's Avatar
Old51f3
I take it it’s a
Canadian. 1BA
Old May 6, 2019 | 05:27 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Yep, so it should have come with rotators, unless Canadian engines were on a different schedule than US. Or it's been rebuilt using the older style valves. Rotator parts have been hard to come by for quite a while.
Old May 6, 2019 | 10:16 PM
Old51f3's Avatar
Old51f3
So if the exhaust valves are different from intake valves
can someone please tell me if this kit is a good purchase
Old May 6, 2019 | 11:00 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Hmmmm, Switzerland, eh? Never knew the Swiss as a big source of old Ford parts. Suspicious, especially since they are using the exact same pictures as this seller: https://www.ebay.com/itm/Ford-Mercury-flathead-221-239-255-new-valves-guides-retainers-keepers-clips/233215627662?hash=item364cbc118e:g:Q~UAA
I realize your being in Canada complicates things, but there are so many reputable vendors in the States, I'd be hesitant to take a chance with offshore quality. Be carefull too, some are selling Chevy valves which are enough longer that they won't work without adjustable lifters and special spacers on the springs.
Are you sure you need a whole set? How many do you need? Are the guides bad? VanPelt Sales sells guides and valve and all the bit individually, an exhaust valve is $8 and a guide is $5.
Note that original intake and exhaust valves are different, but modern replacements can be used for either. (I believe they are exhaust valves, so safe for either).
Old May 7, 2019 | 03:03 AM
big job's Avatar
big job
I don't think anyone mfg. the intake style anymore since the 1970s. We usually buy from Napa which is
Sealed Power and all 16 valves are exhaust, same as valve guides the exhaust guide was phased out
long ago, so now you use intake guides for all sixteen.
Old May 7, 2019 | 05:38 AM
Old51f3's Avatar
Old51f3
Thank you
I will call them up today and order what I need.
I only need the one. Valve. All the other ones seem to be in good shape. .
plus. Just seen they sell a bunch of other oil tank parts that I need as well
MercM47
Jul 15, 2004 07:35 PM
MercM47
Oct 24, 2003 11:57 AM
frankster123
May 7, 2003 05:36 PM
