Trying to get v86 to work. The software seems to start fine and lights light up on the VCM II but when I goto connect to the truck it says it won't read the PCM. Should it read at this point or is it normal to manually enter the PCM number?
In the upper right hand corner of IDS do you see two arrows
one pointing right and the other to the left and they are green?
Do they change from green or go away?
