Gatorback install question
Old May 4, 2019 | 08:35 PM
thewholetruth's Avatar
thewholetruth
Hi all,
Hypothetically if one didn't realize that the gatorback rear flaps came with both aluminum and stainless steel washers, and mixed them through the install, are they going to be asking for trouble?
It sure was a lot of work putting them on, I'd hate to pull everything off and redo it.
Is there a strong reason they included both aluminum and stainless for different applications?
Thank you.
Old May 4, 2019 | 08:46 PM
burgy's Avatar
burgy
Which ones did you buy?
Old May 4, 2019 | 08:47 PM
thewholetruth
The ones from sharptruck with the brakects.
Old May 4, 2019 | 10:11 PM
flanneljunkie's Avatar
flanneljunkie
Originally Posted by thewholetruth
Hi all,
Thank you.
The aluminum washers are to be used against the aluminum brackets. The stainless washers are used in conjunction with nylon washers. All of this is to prevent any sort of galvanic corrosion. As long as you don't have dissimilar metals making contact, you should be fine.
Shameless plug... I have a full set of gatorback with no metal plates for sale. I opted to go another route. I installed the front ones, then changed my mind. I'd let them go for a good price. If anyone is interested, just send me a PM.
Old May 5, 2019 | 07:41 PM
thewholetruth
any other opinions? Thank you
Old May 5, 2019 | 07:43 PM
speakerfritz's Avatar
speakerfritz
Hi all,
Thank you.
Aluminum washers are for 17 and up
steel washers for 99 thru 16
steel on an aluminum body will cause electrolysis resulting in corrosion
mudslingur
Feb 24, 2011 06:07 PM
Gage2502
Aug 6, 2007 05:47 PM
Rocking M
Garage & Workshop
Jun 12, 2005 11:25 AM
cigarxtc
Paint & Bodywork
May 2, 2003 09:34 AM
