Do I need an alignment?
Old May 4, 2019 | 05:30 PM
SgtNick_PSD's Avatar
SgtNick_PSD
Hey fellas, I just replaced the tie rod end that connects to the pitman arm because it was loose and I was having minor steering issues. I know you're 'supposed' to get an alignment after replacing any of those issues, but I measured and remeasured and counted the threads and recounted, and it's all perfect. I'd also had steering wheel wobble at 70mph before and it's smooth as butter at 80mph now. Do I need an alignment?
2000 F250
Old May 4, 2019 | 08:29 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
No. It was to short ffg or FTE.
Old May 4, 2019 | 08:30 PM
SgtNick_PSD
Please explain what you said? I don't understand what ffg or fte means..
Old May 4, 2019 | 11:31 PM
pirate4x4_camo's Avatar
pirate4x4_camo
even if you put the new one on exactly the same as the old how do you know the slignment was ideal before ? if it has not been aligned since the time when that worn out part was good then odds are it is needied an alignment long ago.
I would have it aligned with the toe set to +.03* to +.06* and at least +3.5* caster
fords alignment specs are so wide it is amazing how poorly the truck can handle and still be “within spec”.
I dont align to spec I tune my alignment to achieve a desired result and make it handle like i want. its a lost art nowadays at the big franchise shops with kids doing what the computer tells them, they have no clue what or how the changes they sre making effect the handling
yes you need an alignment.....almost everybody does including brand new trucks or just live with what they give you.
Old May 5, 2019 | 07:46 AM
Walleye Hunter's Avatar
Walleye Hunter
I don't know what the 'ffg' stands for but the 'fte' is the name of this website. His answer is 'no' but you need to have a minimum number of characters to post so he had to add some to it for fte to let it post.
Old May 5, 2019 | 07:50 AM
SgtNick_PSD
Thank you!! That is incredibly helpful. I'll get that done this week. I'll also bring up those specific specs. Wish I could do it myself though...
Old May 5, 2019 | 07:52 AM
SgtNick_PSD
I knew FTE was what people referred to the site as but it didn't make sense in that comment...
Would have appreciated a bit more effort put into the comment haha. Much thanks to you sir!
Old May 5, 2019 | 10:49 AM
pirate4x4_camo
you can if you have the correct tools, 600-1000 bucks would get you a DIY alignment setup and then you can tune your own as you please
Old May 5, 2019 | 12:42 PM
'88 E-350's Avatar
'88 E-350
Replacing that component doesn't change your alignment, it'll only change the steering wheel position which is an easy DIY adjustment. But as already said, if the alignment wasn't known to be good then go do it.
Old May 5, 2019 | 09:27 PM
truckeemtnfords
Sorry Nick, as Mark said I needed a minimum amount of letters to post and No was to short and my fat fingers on my phone don't do what my head tells them to do. The answer to your question reference the part you replaced is a big fat NO. That part does not have any effect on the the alignment, it only effects the steering wheel clocking as stated. But as also mentioned if it was out before then it can't hurt unless the parts replacer (as there are not many mechanics anymore) screws it up worse than it is.
Old May 9, 2019 | 04:02 PM
SgtNick_PSD
Thanks guys. I'll get an alignment done when I get tires replaced soon here then. I won't stress about it immediately.
Old May 9, 2019 | 07:28 PM
Dan V's Avatar
Dan V
You can't count the threads! Who says the new part is the exact same length as the old? You're really looking for the center to center distance. But yes, the part you replaced will only affect steering wheel position.
Old May 9, 2019 | 09:50 PM
SgtNick_PSD
Originally Posted by Dan V
Who says the new part is the exact same length as the old?.
I say. lol like I said I measured again and again. As well as counted the threads. I'm 100% sure I got it exactly the same as the old one.
Old May 10, 2019 | 01:53 PM
brian42's Avatar
brian42
Veteran: Navy
Although you are only talking about pitman-arm-to-knuckle which only affects steering wheel position I did a similar effort when doing the real thing (affecting the toe). I replaced my steering components between the knuckles many a year ago. Measured 15 times (okay maybe not 15, but at least 5 times) before removing, lined everything up, put it all together, re-measured and adjusted, then took it in for an alignment. It drove okay but could tell I didn't get it exact as the old components had been doing the job for 10 years. Long story short when I got the sheet after the alignment the toe was w-a-a-y off when they started.
Just my .02
frdf250
Mar 14, 2024 06:24 PM
crampus
1997 - 2003 F150
Dec 12, 2014 09:30 PM
OleGrouch
Aug 17, 2012 10:37 PM
ItsAFord55
Apr 8, 2012 12:30 PM
roaky81
Nov 10, 2004 09:22 AM
