Difference between 4" and 5" exhaust
Old May 4, 2019 | 09:12 AM
Bohen's Avatar
Bohen
So I'm thinking about going
Old May 4, 2019 | 10:22 AM
Andrew010's Avatar
Andrew010
5” is bigger, therefore cooler!
Old May 4, 2019 | 11:34 AM
Bohen's Avatar
Bohen
Lol , what's the plus side ?
Old May 4, 2019 | 11:56 AM
kper05's Avatar
kper05
How much HP did you add?
Edit: You said tow tune so minimal HP increase (30?), I read but didn't comprehend. I'd say keep the 4 inch. 5 inch exhaust isn't going to provide much benefit. Possibly it'll slightly lower EGTs and a different exhaust tone but you would be changing it just to change it in my opinion, which you could certainly do. The turbo outlet is 4".
Old May 4, 2019 | 12:08 PM
bobcat67's Avatar
bobcat67
most 5" kits are still 4" until a couple feet after the downpipe, they sound better in my opinion, but beyond that there is no benefit to be gained from them. Changing the downpipe to a bigger one without all the bends/restrictions in it would be a good idea, it's not the easiest thing to do though, honestly helped having 2 guys when doing mine.
Old May 4, 2019 | 04:32 PM
Just Strokin's Avatar
Just Strokin
sometimes changing exhaust size can lower your MPG.
Old May 4, 2019 | 04:37 PM
Bohen's Avatar
Bohen
[QUOTE=kper05;18635437]How much HP did you add?
Old May 4, 2019 | 06:59 PM
Bohen's Avatar
Bohen
Is there any difference from a dpf delete racepipe to a full delete exhaust?
Old May 4, 2019 | 07:05 PM
bobcat67's Avatar
bobcat67
I believe a lot of the factory piping sizes are 3.5" not 4"
Old May 4, 2019 | 07:09 PM
Bohen's Avatar
Bohen
[QUOTE=bobcat67;18635915]I believe a lot of the factory piping sizes are 3.5"
Old May 4, 2019 | 07:15 PM
bobcat67's Avatar
bobcat67
if sound is what you're after, a 5" with or without a muffler will sound the best, if you do a lot of towing, I would recommend a muffler. Sometimes there is clearance issues with 5" over the axle if you have a gooseneck plate, 4" sounds good too, I'd highly recommend a down pipe though if you're really wanting the best sound/least restriction, although there is minimal restriction if any at your horsepower levels with any of the systems including stock with the truck missing the heavy parts
Old May 4, 2019 | 07:48 PM
Bohen's Avatar
Bohen
[QUOTE=bobcat67;18635926]if sound is what you're after, a 5" with or without a muffler will sound the best, if you do a lot of towing, I would recommend a muffler. Sometimes there is clearance issues with 5" over the axle if you have a gooseneck plate, 4" sounds good too, I'd highly recommend a down pipe though if you're really wanting the best sound/least restriction, although there is minimal restriction if any at your horsepower levels with any of the systems including stock with the truck missing
Old May 4, 2019 | 08:03 PM
bobcat67's Avatar
bobcat67
the down pipe is what hooks up at the back of the turbo and goes down, the factory one is kinked and bent in a few places, after market ones aren't. That being said they're kind of a pain to install. The resonator on the factory exhaust is see through so it doesn't cause much if any restriction. Other than sound there really isn't much gain to be had from what you currently are running
Old May 4, 2019 | 08:25 PM
Bohen's Avatar
Bohen
Thank you Sir
Old May 4, 2019 | 11:00 PM
Army RET's Avatar
Army RET
This is contrary to what's been suggested earlier (additionally it comes from an unknowledgable source), but if sound is what you want then stock is best. I seriously dislike noisy pipes/ trucks.
And while I'm pleading my ignorance I'll also admit to my avoiding trucks with lifts and/or emission deletions.
Come resell time I wouldn't touch any of them.
