dtc code p0151
Old May 1, 2019 | 04:26 PM
stinson 108-1's Avatar
stinson 108-1
stinson 108-1
dtc code p0151
My 13 3.5 eco has the bank 2 sensor 1 oxygen sensor code p0151. I want to replace with an oem sensor which I believe is pre cat located on the driver side below the turbo. Anyone know for sure, have a part number?
Old May 2, 2019 | 05:25 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Go to Tasca.com and enter all the relevant vehicle info and you'll be able to source the part you need.
I just had the same O2 sensor replaced at the dealer because my shoulder is jacked at the moment. Turns out that the bank 2 sensor is the more expensive of the two. It apparently has a longer harness but it was only 30 minutes of labor for them to do it.
Old May 2, 2019 | 05:36 PM
stinson 108-1
stinson 108-1
Thanks for the reply. The check engine lite went away yesterday. I"m sure it will come back. I"ll get the part and replace it anyway. Thanks again.
Old May 3, 2019 | 06:10 AM
tseekins's Avatar
tseekins
Yes, it's like a bad dream, never completely goes away until it's replaced.
air1jpg
2004 - 2008 F150
Feb 19, 2014 09:22 PM
thunderbird1986
Oct 21, 2013 07:30 AM
MikeRizz
Mar 24, 2010 09:56 AM
elrodalonzo
Apr 17, 2006 10:14 AM
tosterbe
Jan 7, 2003 10:46 AM
