Brass for egt probe?
Old May 1, 2019 | 10:36 AM
jethrodean's Avatar
jethrodean
Hey guys. I got my new egt probe for my 6.7. I dropped the piece that goes around the probe. It looked brass. Cant find it because i managed to drop it over the engine. I was wondering if it is just brass of i could go to the hardware and find one thatll fit the probe.
Old May 1, 2019 | 11:19 AM
Just Strokin's Avatar
Just Strokin
simple answer is no....brass melts at a temp lower than steel
Old May 1, 2019 | 11:31 AM
jethrodean's Avatar
jethrodean
That blows. Gonna have spend 160 on another probe.
Old May 1, 2019 | 11:44 AM
jethrodean's Avatar
jethrodean
This is what the piece i dropped looks like.
Old May 1, 2019 | 11:47 AM
dirthawg's Avatar
dirthawg
The part you are referring to I assume is just a reducing pipe nipple? Could you not purchase a stainless or steel reducer from said hardware store? Just your luck Ford most likely used some proprietary thread that is non-standard.
Edit: I see you replied before I did. That looks like a standard brass compression fitting sleeve to me.
Melting point of brass 1700F
Old May 1, 2019 | 11:58 AM
jethrodean's Avatar
jethrodean
I apologize. I forgot to mention my truck is deleted. I went with a livewire and a sct egt probe.
Old May 1, 2019 | 12:22 PM
Just Strokin
if you are away from the high heat, then the compression sleeve/ferrule might work made from brass. You didn't fully explain what part was needed. Go to local parts store or hardware and acquire a compression coupling and try it.
Old May 1, 2019 | 12:24 PM
Just Strokin
Better yet, contact SCT and ask them what will work....they have a toll free number for tech support...They might send you a new one for free or low cost
jlmotox
Sep 29, 2011 08:50 AM
Oslo
Aug 5, 2011 07:46 PM
Culvert
Sep 17, 2009 01:54 PM
sgrol
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Apr 24, 2006 04:23 AM
