You can get them off eBay or from your local Ford dealer. Most of us with the 2011-2016 trucks keep a spare on hand. I have one in my truck tool box with spare filters also. Not sure if local parts houses have them or not.
Yes,, it has the drain port and the WIF sensor openings in the cups.....but they are not included...you have to swap yours over....make sure both o-rings remain on the yellow drain plug....also lube the o-rings with clean fresh motor oil....yellow plug o-rings and the big green o-ring.
White Bear had the better price by a couple bucks, but kept trying to make me pay via paypal, which I don't have. After two attempts on a CC, I went to Amazon.
I have two caps coming. Shipping to AK will be a week. Still need to try my local dealer partsdept to get this truck running again.
I have the "C" revision. I haven't broken one yet but am using the replacement currently, it has almost 30k miles of fuel through it by now. My OEM is now my spare.
I don't know what my OEM revision is but both visually appear identical, such as plastic thickness.
It had some algae bits in it two filters ago, I didn't feel like cleaning it that day so just swapped to the new spare. The new one had a soft protection-type material around it anyways.
I think they are still interchangeable. I suppose I will find out one day as my truck was made 5-12-2014 and the DFCM was replaced as a unit last year. Have not looked to see what the cup looks like on it. I carry a spare BC3Z.
