Transmission Leak
Old Apr 30, 2019 | 04:17 PM
ShotgunZ71's Avatar
ShotgunZ71
Transmission Leak
I recently noticed a slight leak under my F-250 6.2 Platinum. Not a bad leak, more like a weeping-type of leak. It appears to be coming from the top of the area right where the transmission and transfer case join. Wondering if anyone has had anything similar and what was cause, if so. It's not bad by any means, but I'm getting it look at first of next week before it becomes a bigger issue.
Old Apr 30, 2019 | 05:21 PM
cattaco's Avatar
cattaco
There's several of us who have had this problem. Mine was leaking transfer case fluid. Took it to the dealer and they replaced a gasket.
Old Apr 30, 2019 | 08:56 PM
ShotgunZ71's Avatar
ShotgunZ71
Appreciate the info. Hopefully it is something simple as what you had.
Old May 4, 2019 | 11:10 PM
America78's Avatar
America78
I had this with about 10,000 on my '17 6.2 SC SB 4x4. Dealer replaced a seal between transmission and transfer case. The fluid dripping off of the leak on to the exhaust and vaporising/smoking is what brought my attention to it.
Old May 5, 2019 | 07:16 AM
ShotgunZ71's Avatar
ShotgunZ71
That’s the place. Dropping it off tomorrow. Hope they can get to it this week. How long should I expect?
Old May 5, 2019 | 09:00 AM
jimzpsd's Avatar
jimzpsd
It depends on how backed up the dealer is with other repairs. But to consider a proper diagnosis and an available tech along with the part in stock............two hours, tops. But we all know it won't go that way, lol.
Old May 6, 2019 | 01:56 PM
ShotgunZ71's Avatar
ShotgunZ71
They took the truck back this morning, cleaned everything up and verified the leak. They tightened some bolts and sent the truck on it's way. I'd imagine the pan bolts and transfer case to transmission bolts. Everything has been clean so far. They told me keep an eye on it and to bring it back if I notice the leak has returned.
Old May 9, 2019 | 10:18 AM
ShotgunZ71's Avatar
ShotgunZ71
Well, the leak returned. All signs that I can see point to a seal that slowly leaks when run cold. On a longer trip where everything gets up to temp, there is no noticeable leak. However, on short trips, it drips. They are going to check it again next week. They've been great to work with.
Old May 14, 2019 | 02:56 PM
ShotgunZ71's Avatar
ShotgunZ71
They replaced the transmission pan gasket today. Hope that was the fix! Have a camping trip coming up, so it'd be tight to get it back in before then if the leak returns.
Anutterford
Feb 28, 2005 12:25 PM
orange peel
Apr 7, 2002 01:25 PM
whiteroc
Mar 21, 2001 06:37 PM
