Sync3 , Android Auto, incoming calls problem
Old Apr 30, 2019 | 09:24 AM
sdetweil's Avatar
sdetweil
i have a 2018 F350, Sync 3.
when wire connected to truck, and Android Auto is running, an incoming call is connected, but I can't hear them, and they can't hear me.
if I MAKE the call, all is ok.
if I disconnect the cable, all is ok..
i have not found a way to recover the call while in progress.. unplug, but nothing changes.. phone says its on handset (or i can change to speaker) but no change
doesn't look like its on Do Not disturb, or Privacy mode.
anyone else experience this?
Old Apr 30, 2019 | 09:36 AM
Wyldfire's Avatar
Wyldfire
Android phone? If so has it upgraded to Andoid 9? If so Google android 9 bluetooth issues and follow suggestions to troubleshoot.
Old Apr 30, 2019 | 09:38 AM
Wyldfire's Avatar
Wyldfire
https://www.ford-trucks.com/forums/1...ora-issue.html
Old Apr 30, 2019 | 09:50 AM
Wyldfire's Avatar
Wyldfire
http://www.reddit.com/r/AndroidAuto/...ing_t1_drmumww
Old Apr 30, 2019 | 10:12 AM
sdetweil's Avatar
sdetweil
Yes, Android phone, else it wouldn't work.
Yes just upgraded to v9
Old Apr 30, 2019 | 10:20 AM
Wyldfire's Avatar
Wyldfire
The update is your problem. You just need to change some settings to get phone and sync on same page.
Old Apr 30, 2019 | 10:24 AM
Wyldfire's Avatar
Wyldfire
I would start with enabling dual mode on your phones bluetooth advanced settings. It can be a simple as your phones media setting volume is off. Dual mode will allow your phones volume buttons to turn up phone volume.
Old Apr 30, 2019 | 10:28 AM
Wyldfire's Avatar
Wyldfire
Next I would go into andoid auto settings have android auto turn off wireless when connected. Searching for wireless seams to make bluetooth flakey. Also have it turn location on. My bluetooth will not work with location off on phone. I have Verizon. It seems like with bluetooth 4 the have made it a requirement to have location on
Old Apr 30, 2019 | 12:26 PM
sdetweil's Avatar
sdetweil
thanks. my phone (OnePlus 5) doesn't have a Dual Mode bluetooth setting..
Old Apr 30, 2019 | 12:44 PM
sdetweil's Avatar
sdetweil
thanks for all the help and guidance... it seems AA version 4.5 onward has implemented Do Not Disturb ON by default, with no way to disable that function...
Old Apr 30, 2019 | 06:29 PM
Wyldfire's Avatar
Wyldfire
Yes I had to make changes there also. I used as a guide:
https://www.digitaltrends.com/mobile...de-in-android/
Old Apr 30, 2019 | 07:18 PM
sdetweil's Avatar
sdetweil
Thanks. I need to turn it OFF , but Android auto turns on dnd
Old Apr 30, 2019 | 07:27 PM
Wyldfire's Avatar
Wyldfire
Might go through you Google assistant settings. I would think that is causing the issue in android auto.
Old Apr 30, 2019 | 08:36 PM
sdetweil's Avatar
sdetweil
changing to earlier Bluetooth version, using app to disable DND, checking all the other settings.. nothing improved..
when wire connected, incoming calls cannot hear me, nor me them.. i can call out just fine.
when not wire connected, all is ok
Old May 1, 2019 | 12:21 AM
Wyldfire's Avatar
Wyldfire
Make sure location is on then turn do not disturb off.
