2003 7.3 CPS
Old Apr 30, 2019 | 06:42 AM
Lockholder's Avatar
Lockholder
2003 7.3 CPS
I replaced my CPS a few months ago. Had no issues and then it snowed and had a few issues with the truck shutting off and CEL and s code then it all stopped. Now it’s raining and I got a CEL code and the jerks. so it only happens during bad weather lol. Should I just replace it again.
Old Apr 30, 2019 | 07:12 AM
Walleye Hunter's Avatar
Walleye Hunter
Do you have water intrusion at the fuse box? Did you use OEM CPS to start with? If you used aftermarket I'd change to OEM.
Old Apr 30, 2019 | 07:48 AM
Colorado350's Avatar
Colorado350
X2. I would bet that you have a leak at your windshield seal.
Old May 1, 2019 | 04:32 PM
Brother Les's Avatar
Brother Les
Had this happen to me a few years back. Drove through a large puddle of water in the rain and truck shut off. It was the CPS.... The CPS was not 'bad', but moisture was finding it's way in and shutting the truck off. Unplug the CPS and take it out. Clean everything up on CPS and Connections and seal everything well with Dielectric grease. Connections tight and CPS sealed and tight. keep moisture out. I have had no more 'shut downs'.
cabloom300
Jan 11, 2014 10:43 PM
7.3mule
Aug 17, 2008 02:38 AM
rosa70
Jul 10, 2007 05:19 PM
Clint Knotts
Jul 9, 2006 12:03 AM
