Yay, no emissions anymore. Header question
91 F250, 302, 5 speed. Has factory replacement exhaust manifolds, and exhaust from cat back is new. Only use it for a occasionally daily driver, and tow a light travel trailer a few times a year, mainly to and from hunting camp. Should I look at headers into a new exhaust? Any benefits? All emissions system is in good shape and works well. Not looking to delete any of that, just wondering if I can get slightly more power, and better mileage with a new exhaust system.
Thanks
Thanks
Dont remember the cam part #, but, it was a comp cam recommended by several others here. Wondering about a complete header exhaust package, deleting the cat, and how that woumd work with the smog pump. Since all emissions are working fine, just wondering about deleting the cat, and going to a straight header and exhaust.
Reviving kind of an old thread I posted. But, here goes. I am considering a complete exhaust retro fit. From manifolds back. Looking for a little more power, and mpg. How do I make this work with my current emission/smog pump setup without bad run ability, or throwing codes? Do I discard the O2 sensor and cap all the vacuum lines? What do I do?
Thanks everyone.
Thanks everyone.
The EEC-IV (OBD-1) computer looks at the upstream oxygen sensor to adjust the fuel injectors. You cannot delete the oxygen sensor and expect the computer to know how well it is adjusting the fuel mixture. There is no downstream sensor so the computer does not know if the catalytic converter is still there nor does it care. I used shorty headers, y pipe into a high flow converter and a chambered muffler with dual outlets. Another option is long tube headers and then have a shop fabricate a dual exhaust system with or without a crossover pipe.
I deleted the air pump on my 302, installed an idler pulley in its place and followed the rest of the delete procedure spelled out in one of the many threads about this topic.
If it needed to be done, headers to an H pipe with the O2 sensor bung in the - of the H would replicate what the current setup is seeing (I'm assuming a '91 had the single 02 sensor).
What you are looking for is as you've been told, a Manifold/Cam/Header setup to get what you want. By the time you do all that you'd be better off just building a whole new mill on a 351 block with an aftermarket FI system.
Not worth it if all you want is a little more power and better MPG.
You'd do better to just keep what you have in proper tune.
Received 1,353 Likes
on
The following 3 users liked this post by Fomoko1:
The following users liked this post:
86Stepside
09-12-2014 09:56 AM
lippsenator
05-03-2011 08:06 AM
ironhead86
03-05-2011 06:28 PM
DrFordG
02-16-2007 02:13 PM
