Best place for repro wipers
Old 04-29-2019, 10:43 AM
jwitty's Avatar
jwitty
jwitty is offline
My rubber is bad on my wiper blades and the metal piece that the rubber attaches to is rusted and pitted bad. Where’s the best place to get good reproduction ones? Dc?
Old 04-29-2019, 10:58 AM
ibuzzard's Avatar
ibuzzard
ibuzzard is online now
Panties NOT in a Twist
I have had good luck with eBay, and NOS or NORS, OEM. No problem with hard rubber.
If you use the search function, you can find threads listing parts numbers for the aftermarket manufactures like Anco or Trico, possibly others.
You may want to test the tension of the existing wiper arms, they do deteriorate. I have an old tension tester. New rubber refills with worn out arms will show you no improvement, they can actually be lifted by normal airflow going down the road, and will float instead of gripping the windshield.
Old 04-29-2019, 11:21 AM
TA455HO's Avatar
TA455HO
TA455HO is offline
I'd like to see a pic of the old tension tester if you have one. Is it an Anco brand Tel-Tale?
Chad
Old 04-29-2019, 01:26 PM
BarnieTrk's Avatar
BarnieTrk
BarnieTrk is offline
ibuzzard,
If they do test weak, can you adjust them to hold the windshield better or do you simply replace them?
Thanks in Advance,,,,,, BarnieTrk
Old 04-29-2019, 02:00 PM
ibuzzard's Avatar
ibuzzard
I think there is a spring in there which can be changed out by a person more inclined/less lazy than me. I would just change out the arms.
That tester is a sales tool. I used to sell TBA (Tires, Batteries, Accessories) when I worked in service stations prior to my career as an IBEW electrician(retired). Part of my wages were based on how much TBA I sold.Now I sell hotdogs/sausages, and am payed to insult , er, I mean tease old farts like myself. I haven’t had my teeth knocked out yet - but it’s early days.
Remember full service gas stations? You could get a fill-up, all windows and headlights cleaned, fluids and tires checked, get some S&H Green Stamps, and a different piece of dinnerware or silverware or bath linen each week , if you’d but “fill her up with Ethyl”?
Now you're lucky if they’ll let you use the restroom, and most of the two bay stations are history, having been turned into more profitable C-stores. I miss those greasy old stations of my youth.
Old 04-29-2019, 02:04 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
C1SZ-17526-A .. Wiper Arm - Adjustable - 12 1/8 to 16 3/4" / Obsolete
1961/66 F100/1100 / 1963/69 N/NT500/1000 / 1967/69 F800/1000 // 1961/65 Thunderbird // 1961/67 Econoline // 1965/69 Mustang/Fairlane/Falcon/Comet.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
KAMA OBSOLETE PARTS in East Bethel MN has 1 = 763-434-0123.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1 = 800-476-9653.
OBSOLETE RELIABLE PARTS in Nashville GA has 6 = 229-686-5101.
B8SZ-17528-B (replaced B9AB-17528-A) .. Wiper Blade - 12 7/8" long (Trico), dull finish / Obsolete
1961/66 F100/1100 / 1963/69 N/NT500/1000 / 1967/69 F800/1000 // 1958/60 Thunderbird / 1959 Ford Passenger Cars.
MUSTANG'S ETC in Van Nuys CA has 2 = 818-787-7634.
MCDONALD OBSOLETE PARTS in Rockport IN has 2 = 812-359-4965.
B9AB-17528-A =
NOS PARTS SOURCE has 1.
HILLTOP CLASSICS in China Grove NC has 2 = 760-746-0400.
Old 04-29-2019, 03:34 PM
BarnieTrk's Avatar
BarnieTrk
I did not know there was a replaceable spring....
Yep, I remember full service gas stations. I worked at one such station. I assisted in the stripping out of the mechanical gear in the two bays and then we moved in pallets of Ralston Purina feeds. We sold anything Purina out of those bays... including loading out lots of dog chow, rabbit chow, cat chow... and we still pumped in your gasoline, checked your motor oil, windshield washer fluid, cleaned your windows & lights and checked the air pressure in all five of your tires. All for 2$/hour.
BarnieTrk
Old 04-29-2019, 03:49 PM
ibuzzard's Avatar
ibuzzard
Was just on eBay a little while ago, searching Vintage Car and Truck Parts for “Trico”, saw some of those replacement springs on auction, cannot tell you how to change them out.
Old 04-30-2019, 07:53 AM
skidoorulz's Avatar
skidoorulz
skidoorulz is offline
https://www.ebay.com/itm/TRICO-WIPER...kAAOSw27dcw5Dd
Here is one if you are looking for one.
Chad
mediaman67
1997-2006 Expedition & Navigator
12-11-2018 02:50 PM
FlaresideF150
09-25-2012 11:26 AM
4inchlovin
1999 to 2016 Super Duty
01-30-2010 04:33 PM
weekendwarriorfsw32
11-21-2008 05:47 PM
Ed
Aerostar
11-25-2005 10:41 AM
Quick Reply: Best place for repro wipers
