Srw or Drw
Old Apr 29, 2019 | 09:38 AM
oxt127's Avatar
oxt127
Srw or Drw
Currently towing with a crew cab 8-ft bed 1 ton single wheel. Did anyone here go from a single wheel to a dually? Do you feel that it made a big difference in handling? Looking to maybe purchase a new truck next spring not sure if I really want to go with the dually or not, I know weight wise it's not required. I pull a Grand Design 311 BHS that grosses at 14,000 lb and 37 ft. I could probably be more talked into the Dw if they offered the wide track front end again in 350 as I don't want the 4:30 gears or 19 and 1/2-in wheels that come on the 450. I would likely order the dually with the same gearing as the single wheel 3.55 assuming they stay with that in 2020.
I will stick with the diesel probably will not consider the new 7.3 gas.
Old Apr 29, 2019 | 10:14 AM
scraprat's Avatar
scraprat
Top Answer: 5
Dually will always out perform a srw while towing but there are trade offs.
I personally like the dually for the stability especially where I drag the 5th wheel in the off road conditions. Never really gave it much thought to steering, if it takes a little backing/ forward for maneuvering not the end of world.
The down side is if you do back road trips, might have to be planned a little more or be more daring where/ willing to go.
Old Apr 29, 2019 | 03:00 PM
RV_Tech's Avatar
RV_Tech
Pros and cons both ways. Duallies add stability, but if you do a lot of in town driving in congested areas we found out dually to be a pain and our reality is even though we haul out truck camper a lot and our fiver at times, more often we are driving our truck with much lighter loads as in trips to Lowes or Home Depot and far more often around town then on the Interstate. it's just another of "it just depends" kind of question in my opinion. Thus we are happier with our SRW than we were with our DRW and the trade off in handling when towing doesn't seem to be much.
Old Apr 29, 2019 | 09:07 PM
2009kr's Avatar
2009kr
Reconsider an F450 if you go with a dually. They turn tighter than even a short bed SRW and have great stability. I find it easier to park than a long bed SRW, especially with the 360* camera system. They are also fantastic backing a long fifth wheel. I daily drive mine.
I like the 19.5" tires. They are very strong, last a long time, and tow very well. The 4.30 gears make the truck more fun to drive, tow better, and for me, don't seem to impact fuel mileage much. My F450 is still very quiet, even at 75 MPH and averages 15 MPG when empty (14.5 in the winter, 15.5 in the summer).
Old Apr 29, 2019 | 09:11 PM
First Dually's Avatar
First Dually
A F-450 for the wide front end (tighter turning radius) for sure!
Old Apr 30, 2019 | 05:29 AM
orion1968's Avatar
orion1968
I went from a 2017 F250 to a F450 and would not go back. The turning radius, 5th wheel stability, bigger breaks, and beefier axle far out weigh the unloaded in town cons. I find it much easier to park than the F250 with the wide track turning radius. Helps with backing the 5th wheel into tight spaces too.
Old Apr 30, 2019 | 07:08 AM
oxt127's Avatar
oxt127
If the 450 could be had without a 4:30 rear and 19.5 rims I'd be sold easily. I don't really want to try and buy tires several times for those rims and the choices are severely limited, in comparison.
Old Apr 30, 2019 | 07:27 AM
orion1968's Avatar
orion1968
They do last 60-70k miles compared to the Michelin's that were on my F250 that were almost done at 30k when I traded it.
Old Apr 30, 2019 | 07:33 AM
oxt127's Avatar
oxt127
They may. But I also don't want anything close to a highway tire. I need to drive in snow and off road. I've put the Goodyear Kevlar tire on each of my trucks I've had over the past 10 years and like how they perform for me, and I've gotten about 50-60k out of those.
Old Apr 30, 2019 | 08:01 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
I've towed with both and as long as I'm pulling large trailers I will always have a DRW, some leaning curve but after that even the wife takes it anywhere she wants to go.
Denny
Old Apr 30, 2019 | 08:19 AM
nuctrooper's Avatar
nuctrooper
check out the Goodyear G622 or the Toyo M608Z. Both fit the bill, have double the tread depth of LT tires, and last over 80k. I run the M608z on my 450 x works great in snow and dirt. Mine have 33k miles on them, and the tread depth is still deeper than a brand new LT tire.
There’s absolutely zero reason to fear 4.30 gears, too. Only people that don’t have a 450 say the 4.30 is too short. Everyone with one says that 4.30 is fine.
Just go test drive one. Find one with the 360 camera. Take it on the highway and pull it up to the speed limiter. It’s not screaming, it’s just driving along. Then take it to the Walmart parking lot and back it into a space. Then go back to the dealer and sign the papers. Swap out for 245 wide (or 265) M608Z and sell your new stock tires to help offset the cost. You won’t look back.
Old Apr 30, 2019 | 09:02 AM
oxt127's Avatar
oxt127
Appreciate the input on tires, I know there is some options out there. I do a pretty fair amount of unload miles so that's really my reasoning for wanted the 3.55 over a 4.20 if that's what the 20s end up having. Every mile counts a lot when you can only assume to get 15-18
Old Apr 30, 2019 | 09:24 AM
nuctrooper's Avatar
nuctrooper
Agree on the mileage. I get 13 around town and 14.5 on highway (though I am running 285s, so taller and heavier than stock). I can’t even touch the 15+ that some guys get.
Old Apr 30, 2019 | 10:37 AM
RA12726's Avatar
RA12726
Banned
We moved from a SB CC SRW to LB CC DRW truck towing a Reflection 337RLS fifth wheel that specs out very much like yours (3,000 lbs. on the pin). LOTS of difference in how the rig handles while towing. As mentioned, there are trade-offs and it all depends on how much you tow. We are full-timers and put 12 - 14K per year on the truck and trailer, so the trade-offs were very much worth it for us. After we traded trucks, my wife started telling people I would let her buy more than 6 rolls of toilet paper...
Rob
Redpine
Oct 17, 2019 12:44 AM
ExDakotaOwner
Feb 27, 2018 04:30 PM
Steven Walch
6.7L Power Stroke Diesel
38
Mar 20, 2013 12:08 PM
TheRifleman
29
Oct 15, 2010 12:08 AM
csherman4383
Jul 29, 2005 08:44 PM
