rear sliding window
Old May 5, 2019 | 02:16 PM
four-sixty-power's Avatar
four-sixty-power
Originally Posted by Jarrett Campbell
Good luck with the wing window gasket... I spent like two hours getting mine in the frame and it still leaks air....
Between the vent window and main window there is a metal tab that holds the outer metal door skin and inner metal door skins together, so a tab from each skin that is spot welded together with 1 spot weld, this weld can break, then the gap between inner and outer door metal "grows" and no matter what you try the vent window seal will LOOK like it is too small to cover over the outer door skin and leave an air gap. CHECK THIS TAB. If the weld is broken you can use a self tapping screw to attach them back together, the screw wont interfere with any seals, the gap should be consistent all the way along where main window and vent window sits.
Old May 5, 2019 | 02:19 PM
four-sixty-power
Sometimes new seals / weatherstripping aren't perfect and can have "extra" material that needs to be trimmed to get a good fit, I had to trim bits when I did my vent window seals, I got mine form Macs auto parts.
Old May 5, 2019 | 03:17 PM
breezesboy's Avatar
breezesboy
Coming along...
Making progress but it’s a slow go with paint curing and recoating times.
Prior
Currently
Still needs stripped primed and painted
Old May 6, 2019 | 04:09 PM
Jarrett Campbell's Avatar
Jarrett Campbell
Yeah, I fixed that tab, the gasket that went in the wing window was too big, so I had to cut the vertical portion on the bottom and trim about 1/2" of the vertical portion off.
It also still leaks air... I can see daylight above the pivot point... Kind of tired of messing with it at this point.
RIPbiker13
17
Oct 27, 2018 12:50 PM
srauner
May 19, 2017 10:48 AM
ghunt
Feb 25, 2008 09:57 PM
dantennant_22
Washington Chapter
Apr 11, 2007 08:16 PM
VelocityDriver
Sep 19, 2004 05:35 PM
