Part Identification
Old Apr 29, 2019 | 06:02 AM
Leculver79's Avatar
Leculver79
Part Identification
Hey guys I’m tearing into my 79 f-100 and I just found these parts laying on top of the engine. Can anyone help me with what they are and where they go.
Old Apr 29, 2019 | 07:33 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Both are emissions related. The first is a diverter valve and the second one is a check valve. Both are part of the air injection system. This system injects air into the exhaust stream to help burn off any unburned fuel.
Old Apr 29, 2019 | 03:56 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
#3 looks like a passenger side exhaust manifold heat shield that connects to the bottom of the air cleaner. 9A603
Old Apr 29, 2019 | 06:44 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The third picture never fully downloaded for me. All I see is about two inches of the hood underside.
Old Apr 29, 2019 | 07:27 PM
niko20's Avatar
niko20
They go into either the trash , or into a box where you keep all the stuff you took off the truck. You don't need 'em...remove the smog pump too. Probably doesn't work anymore anyway. My smog pump/diverter seem to work but I'm pretty sure my exhaust check valve is shot, when I tested it, it lets exhaust back through (it's supposed to be one way). And Oriellys wants $26 just for that valve. I'm thinking I just don't need it, instead.
Old Apr 29, 2019 | 08:54 PM
meangreen92's Avatar
meangreen92
The first pic looks an awful lot like a Diverter Valve, which routes air from the smog pump to either the exhaust ports, or downstream into the exhaust, probably past the catalytic converter. Diverter Valve will have an inlet from the pump, and two outlets.
The second pic is of a hose with a check valve in the end. Pretty sure the check valve is keeping fresh air out of the hose, and if there were anything pressurizing the hose, the check valve would let it out. So I'm guessing that the check valve was attached to either a tube which bolts to the backs of the heads, or to one of those spider-looking deals which inject the air into the manifolds, rather than the heads.
The third pic I can't tell what it is. It looks like an exhaust manifold with a dump-pipe on it...
Old Apr 29, 2019 | 09:15 PM
niko20's Avatar
niko20
Ah, forgot to mention, if you have a catalytic converter than actually you need to keep the smog pump or you'll burn out your cat. Cat needs fresh oxygen to do its job
Old Apr 29, 2019 | 10:44 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Pic #1 = 9B289 diverter valve.
Pic #2 = 9A487 check valve.
This little darlin' and the diverter valve are not shown in your pics that I deleted, because they're part of the T/E (smog pump) system.
Pic #3 = 9A603 carb air cleaner air duct shroud.
OP failed to list the engine size, so I cannot post the correct pic or complete part numbers.
rob8210
13
Dec 14, 2024 11:24 PM
JB5587
Jun 13, 2017 02:21 PM
buffalobillsexhaust
26
Sep 24, 2014 09:42 PM
Bodaddio
Aug 8, 2010 01:40 AM
hemi 27
2004 - 2008 F150
Apr 22, 2010 07:19 PM
