Error code 62, need help
Old May 27, 2001 | 02:28 AM
pigsew's Avatar
pigsew
I have a 1991 f-150 4x4 ext cab automatic 5.8l. I am getting a code 62 error reading when running koeo test condition. My book indicates it is "Transmission 4/3 circuit fault". What does this and what is the fix? Thanks for any help.
Kurtis
Old May 27, 2001 | 09:23 AM
Steve91's Avatar
Steve91
My Ford books show that code as being for "Converter Clutch Failure: The EEC-IV module picks up excessive amount of converter slip while converter is scheduled to be locked up."
The pinpoint tests indicated are for the wiring harness, the converter clutch solenoid, and the converter clutch regulator valve and control valve.
Old May 27, 2001 | 09:34 AM
pigsew's Avatar
pigsew
My book shows the clutch fault only as a continuous memory fault under the car EEC section, my continuous memory faults were clean. Under the truck section it shows the Transmission 4/3 circuit fault. What do you show for indicated tests for that fault?
Thanks for your help.
Kurtis
Old May 27, 2001 | 10:17 AM
Steve91's Avatar
Steve91
I guess I can't help you. I am looking at the Ford Engine/Emissions-Diagnosis 1991 Shop Manual, and the 1991 Bronco, Econoline, F-Series, F-Super Duty Truck Manual, Volume 1.
62 is not listed anywhere in these books (car or truck) as a KOEO code. Nor is 69, which is 3-4 shift error. Both are listed only as continuous codes for trucks with E4OD.
If you are in monitor mode doing a wiggle test of connectors or wiring, the code may show up on a VOM or STAR.
Old May 27, 2001 | 12:42 PM
pigsew's Avatar
pigsew
Thanks for checking. That's strange that it's not showing up in your manual. I would trust you books more than my little reader manual. I'll try the wiggle tests and also letting the computer reset and see what comes up. The only thing that concerns me is that I had some strange tranny action on the way to work the other day. Have done a full fluid change since and seems to be running fine now. Just trying to avoid a surprise on our next long trip.
Thanks again,
Kurtis
Old May 27, 2001 | 04:03 PM
soldier's Avatar
soldier
cbrown_63
Nov 21, 2010 09:24 AM
raptor2005
Feb 15, 2010 03:03 PM
roller_steve
Aug 2, 2008 11:35 PM
DUALLYNOTED
Computer Chips & Tuners
Oct 24, 2007 07:56 PM
whobbins
1997 - 2003 F150
Apr 27, 2007 06:37 AM
