Valve adjustment
Old Nov 25, 2019 | 05:57 AM
bigwin56f100's Avatar
bigwin56f100
Originally Posted by seaves46
Those lifters are usually adjusted by getting them to zero gap , this is done while turning the pushrod with your fingers while tightening the nut .
Tighten the nut down until you can just feel resistance on the pushrod while turning with your fingers .
Then give the nut a further 1 turn to put the plunger in the lifter under tension .
Do not tighten the nut until the plunger is right down in the lifter .
not on this engine series. The rocker is to be torqued to 17-23 foot pounds. The lifter does the adjustment
as for lifter replacement , So long as they are still in the same hole they came out of you’re fine. If you’ve mixed them up you’ll need a cam and lifters
Old Nov 25, 2019 | 02:23 PM
Pladsmand's Avatar
Pladsmand
The way to adjust my lifters? I have to cims my rocking arms so it suits that when I have made contact with pus root and here after tightened nut 1 lap the nut should be tightened to the bottom
Old Dec 22, 2019 | 10:32 AM
Pladsmand's Avatar
Pladsmand
thanks all you good guys out there i made chims and now the engine runs perfekt with no noise .
Again i have to thanks you
Merry christmas
Pladsmand
15
Nov 24, 2019 11:14 PM
Johnkimble
Oct 15, 2018 04:10 PM
z31freakify
Sep 18, 2015 05:57 PM
fordboy300
Jun 30, 2012 09:33 PM
86 Bronco
Bronco II
Nov 15, 2004 05:44 PM
