Restoration Project: 1986/300 I6/4x2
#121
I tried, need some better reenforcement. The middle one didn't hold up.
#122
What a PITA putting this replacement dash in has been. The mounting locations are really thick I had to trim them in order to have a hope of getting the nut clips on. The drivers a pillar one keeps sliding on me so it pops the dash up a hair higher than I would like so I will have to work on that
The mounting points all seem to be reenforced with metal.
My bezel repairs held except for one. I will pull this all back apart later. For now it will sit as is.
I used China marker on the window to mark the locations of the vent nuts.
A little extra kill mat in the cab sealed in and screwed in the wire harness in the drivers rocker. Fay sealed and wet installed the hi beam light switch then laid in the carpet so it can start to realax into place. This color is desert tan by acc... Goes well with the saddle and black interior.
#123
Ok I think I am ready to put the seat in the truck. I'm excited because that means doors next and then I can hook up the fuel lines again and drive it around a bit. Letting it sit outside in the sun will also relax the last of the wrinkles out of the carpet.
The hole locations are semi molded into the back of the carpet. Used a soldering iron to cut them out. This melts the edge of the carpet to keep it together. Plunged it in for the threshold.
Installed a plastic bezel for the light switch... Completely upside down. I'll flip it at a later date, not going back out today.
I bought new seat belts from LMC. They are ok, they only have one bolt instead of two so when you go to torque them in, it tries to rotate. My issue with them is it has a twist built in (see pictures). The L bracket needs to be flipped 180 to get rid of this.
Put new door switches in, seem a little different. The passenger side had a plug and no switch, but had the harness so it got one too.
51PanelMan
45
04-14-2013 03:36 PM
wyckedcombo17
195
05-15-2012 11:06 PM
waynaferd
16
10-20-2009 10:33 PM
