Manual Paddle Mirrors
Old Apr 24, 2019 | 01:48 PM
nelsongg's Avatar
nelsongg
Trailering
Have a '99 F350 ext. Cab with manual paddle mirrors on it. I would like to upgrade to a telescopic power mirror.
The question I have, is the wiring for a power mirror sitting in the door as part of the standard wiring harness? Or, is there a connector under the dash somewhere that the mirror can be wired to.
I understand that I will have to change the console on the armrest to one having a mirror controller on it. I figured I could grab one second (junk yard) hand.
Thanks
Old Apr 24, 2019 | 03:34 PM
DieselDenny's Avatar
DieselDenny
Greg, some do some don't. But an xlt should have the loom in place.
Pull the panel and see what you see.
Denny
Old Apr 25, 2019 | 06:46 AM
Firefighter 1406's Avatar
Firefighter 1406
Being that it is a 99 I am guessing you will not have the wiring you are thinking, especially if you have manual mirrors currently. I want to say 03 was the year they starting having wiring there no matter what. I could be wrong. I know when I put the 08 and up style mirrors on my 99 I had the wires for the power mirrors since mine had those to begin with but the turn signals and mirror heat I had to add all myself. Not hard to do but a little time consuming.
Let us know how it goes. Don’t forget the pictures.
Old Apr 25, 2019 | 09:22 AM
dmd's Avatar
dmd
I went with the 08 style (square with large mirrors) in my 2k.. They are really a lot better. I do have the power mirror adjusters though. I didnt add the heat/blinker
options so the mirrors had an adaptor my old style plug could use for the new style mirrors. They are so much better that I would use them as manual mirrors until I got
the wires in place.
Old Apr 25, 2019 | 09:42 AM
brian42's Avatar
brian42
Veteran: Navy
You would have to pull the door panel off and remove the door speaker to find out. It's not that hard of a job. You will want to know what style of plug you have anyway (if you have one).
I'm not sure if you have the mirrors yet but I got mine from 1A Auto and was very happy with them. I was able to order a pair that matched the plug style I had. If not, they have some conversion plugs that can help make the connection without cutting plugs. Again, that's if you have a plug.
I can't count how many times I've taken the door panels off. It is very easy and Ford did a good job designing them for removal (there is no cable to detach as the handle mounts to the door itself and not the panel). For visual assistance, here is a write-up I "borrowed" from the internet...
Old Apr 26, 2019 | 01:29 PM
empiretc's Avatar
empiretc
Yep. Old green is a 99 and was completely manual. Had to install the power switch and run my own cables when I installed the 05-07 mirrors.
Old Apr 26, 2019 | 08:49 PM
Supercab's Avatar
Supercab
Why not just go with manual '08 up trailer mirrors? How often do you really adjust mirrors? (I don't adjust mine very often at all) Just my .02
jamestokelly
Nov 15, 2017 12:44 PM
Supercab
18
Oct 5, 2011 09:04 AM
Rick2001
6.4L Power Stroke Diesel
Jan 13, 2008 08:21 PM
texex
All Things Towing
Feb 27, 2007 05:19 PM
Toored
Jul 18, 2006 08:26 AM
