Sponsored by: Auxito
Brake ABS Problem
Old Apr 24, 2019 | 08:38 AM
fancyvern's Avatar
fancyvern
Brake ABS Problem
I have a 99 F-150 two wheel drive. When I turn left at a slow speed and engage the brakes the ABS comes on and goes through the cycle system. You can turn right or go straight and everything is fine. The ABS light will come on when it happens and when you use the brakes again it will go out. This is when you do not turn left but just normal straight braking. I know some of you will tell me not to turn left and it will be okay but I can't do that. Thanks for reading.
Old Apr 24, 2019 | 01:08 PM
pdqford's Avatar
pdqford
Jack up the front end and carefully check each front wheel for a worn or loose front wheel bearing.
When you turn and use the brakes, the wheel bearing may shift slightly where the wheel speed sensor can’t quite read the ABS tone ring and the ABS thinks that wheel is sliding and invokes the ABS.
mzerio
Aug 14, 2009 01:19 PM
texan2004
Sep 14, 2006 05:43 PM
Exploder-1998
Apr 8, 2005 05:21 AM
AllFords1022
Jan 8, 2004 01:50 PM
rich burris
Sep 16, 2003 09:16 PM
