Anyone have issues getting a u-joint for their 2015?
At at times when shifting the driveshaft play can be felt.
You out might crawl under your truck and attempt to turn the driveshaft both directions to assess any excessive play issues.
good luck
Originally Posted by shootsenmeister
my 2018 has the 9.75 rear end with 3:73 gears. It clucks when shifting from reverse to drive as though the u-joints are shot. However upon my assessment when turning the drive shaft by hand with the engine off, park brake on and in neutral. the excessive play is in the rear end. I intend to have the dealer look at it soon.
good luck
good luck
https://www.rockauto.com/en/catalog/...sal+joint,2392
https://shop.advanceautoparts.com/fi...-u-joint.c5700
https://www.partsgeek.com/catalog/20...e/u_joint.html
here are a few links for u-joints that I’ve found,
the advise for going to a driveshaft specialist in your area is the best option.
Just wondering.
Originally Posted by GABAR
Ummm, since (ARI) is the company who takes care of company vehicle maintenance, shouldn’t it be up to them to find or locate said part for this repair.
Just wondering.
Just wondering.
I was asking if someone had a similar experience so that maybe I could tell the repair shop what part they needed. I move to a new position as soon as my truck gets back and it can't come soon enough.
Got some news this morning though. Ford said it was a bad design and got scrapped altogether. The fix is to order a whole new driveshaft. They don't make that u-joint or a replacement for it anymore.
rangerbait
6.7L Power Stroke Diesel
07-26-2020 09:56 AM
