Sponsored by: Auxito
Rear end "CLUNK" when down shifting.
Old Apr 19, 2004 | 03:45 PM
Stangfire's Avatar
Stangfire
98 F150 2wd 4.2L
I'm getting a "CLUNK" from my rear end when down shifting.
If I shut the overdrive off first it does not clunk.
I did a search and it seems like this may be a common problem. I think I read that the yoke needs to be greased?
Can someone shed some light on this for me and give me some more info on how to solve this problem.
Thanks.
Old Apr 19, 2004 | 04:37 PM
spikedog's Avatar
spikedog
Check out the u-joints. Get under the truck and see if there is any play in the drive shaft. While stopped, try shifting from drive to reverse, then back to drive. Does it clunk then too?
Old Apr 19, 2004 | 10:04 PM
LxMan1's Avatar
LxMan1
Yes, I have read that removing the driveshaft and putting a good coating of grease on the output shaft splines helps.
Old Apr 20, 2004 | 08:14 AM
Stangfire's Avatar
Stangfire
Does it need the grease at the tranny end or the diff end?
I think the U-joints are fine but I'll crawl under the truck and check it out.
