Pulley removal help
Old Apr 22, 2019 | 02:23 PM
Kramercd's Avatar
Kramercd
Pulley removal help
My power steering pump is a remand unit, and I have no idea what kind. Pulley has something like a 3/8" hex in the end with threads in the bottom of the hole. I'm doing the final tear down before paint and I can't see how this pulley comes off.
Old Apr 22, 2019 | 02:44 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It has to be pressed off the shaft, then pressed back on.
Old Apr 22, 2019 | 02:51 PM
Kramercd's Avatar
Kramercd
Ok, just to be clear, press fit, no jam nuts or locking collars or anything crazy?
Old Apr 22, 2019 | 03:21 PM
kr98664's Avatar
kr98664
It's a straight press fit on and off. Get thee a Lisle 39000. Some parts stores will loan them for free:
https://www.amazon.com/gp/aw/d/B000XEX00A?psc=1&ref=ppx_pop_mob_b_asin_title https://www.amazon.com/gp/aw/d/B000XEX00A?psc=1&ref=ppx_pop_mob_b_asin_title
How to use:
I have one and it worked great on my '84.
Old Apr 22, 2019 | 03:25 PM
Rembrant's Avatar
Rembrant
I had a heck of a time removing the PS pulley on my 84. I finally put the whole pump assembly in a chop saw and carefully brought the blade down behind the pulley and cut the shaft off.
I then put the pulley in a proper hydraulic press and pressed the remaining piece of shaft out. Once everything was cleaned up, the PS pulley tool kit worked great to press the new pulley on the new pump.
Old Apr 22, 2019 | 06:50 PM
Franklin2's Avatar
Franklin2
The removal tool will take them off, even if they are stuck. You need two wrenches on the tool, the one autozone rents while less pieces, works better.
ranger332
Oct 3, 2016 09:26 PM
79F150400M
Jun 27, 2010 02:47 PM
Bryan-F250
Oct 27, 2008 05:20 AM
SusanGriggs
Jun 16, 2007 05:13 PM
scottlane
13
Oct 26, 2005 07:13 PM
