Power steering pulley retainer ?
Old Oct 26, 2008 | 06:45 AM
Bryan-F250's Avatar
Bryan-F250
G-day
Does the allen headed bolt that helps hold the power steering pulley on have a right or left handed thread ? (1990 351w)
Old Oct 26, 2008 | 08:49 AM
jr32560's Avatar
jr32560
uh I thought the pulleys were a pressed on fit?it is on my 1990 f150 -302?
Old Oct 26, 2008 | 09:10 AM
EPNCSU2006's Avatar
EPNCSU2006
Yeah, that hex in the end of the shaft is misleading when it comes to the pulley. It may be used in pump assembly, but the pulley itself is pressed on to the shaft. You will need a power steering pulley puller and install tool to remove and reinstall the pulley. Do not use a traditional puller because you can damage the pump internals.
Old Oct 26, 2008 | 12:51 PM
guitar_199's Avatar
guitar_199
This is a special puller that is sort of a "clamshell" in design. It is two halves that fit together ofer the end of the retainer and one lip fits inside the groove that goes around the retainer. Then a metal sleeve slides on over it to hold the puller together . You crank down on the bolt and it pulls the retainer off of the shaft. The hole inside the hex hole is tapped and a bolt helps you pull the retainer back on. You won't do it with anything else.
Old Oct 27, 2008 | 03:07 AM
Bryan-F250's Avatar
Bryan-F250
Thanks guys, I have ordered one of those "clam shell" pullers from NPD, I suspected that the hex hole wasn't a allen headed fastener but now I know for sure. I saw the installer in the catalogue but was wondering what does it screw into to be able to push the pulley on ?
Bryan
Old Oct 27, 2008 | 05:20 AM
guitar_199's Avatar
guitar_199
Just a bolt and washer. They go through the middle of the retainer... you screw the bolt into the hex hole and thread it on.... then just tighten to pull the retainer on.
pete60hill
Jun 27, 2014 12:37 AM
jeff14346
WTB - Parts & other
Apr 1, 2013 09:24 AM
Marky48170
WTB - Parts & other
Jul 28, 2012 07:57 AM
fonz
Aug 20, 2004 01:42 PM
dangerrnager33
Mar 23, 2004 12:12 AM
