Power steering pulley position
Old Oct 2, 2016 | 07:52 PM
ranger332's Avatar
ranger332
I installed a set of CVF racing pulleys last weekend. Everything lines up pretty well but the power steering pulley is a little bit forward of where I think it should be and the v belt is a tiny bit offline. I have the pulley pushed as far back as the install tool will go because it's now hitting the shaft itself which is flush with the front of the pulley. I still have room behind the pulley on the shaft. Does anyone know if it would be alright to push it so that a small piece of the shaft would be past the front if the pulley? I think I can use the same install tool if I use a spacer to allow the shaft to move forward. Any ideas?
Old Oct 2, 2016 | 08:44 PM
ubereal2's Avatar
ubereal2
See if you can find a metal washer that will fit the front of the pulley where the tool fits the pulley. You'll be able to move the pulley back as far as the thickness of the washer.
Unk Bob
Old Oct 3, 2016 | 08:56 PM
ranger332's Avatar
ranger332
I got the pulley back to the position where all the belts are lined up as close to perfect as I care to get. I used the washer method and have a little of the shaft sticking out tge front of the pulley. I notice that there is a little bit of play in the forward and backward movement of the shaft into the pump itself, I would say maybe 1/8 of an inch. Is that normal? I never noticed it before. If it is normal what is the acceptable travel of that shaft into the pump?
Old Oct 3, 2016 | 09:05 PM
ubereal2's Avatar
ubereal2
To have a little play in the shaft is not uncommon.
As long as the pump works, and it isn't leaking, you should be fine
Unk Bob
Old Oct 3, 2016 | 09:08 PM
ranger332's Avatar
ranger332
I haven't noticed any leak and the pump seems to be working fine. No issue with the steering. I just don't want to start shredding belts or anything. Thanks ubereal2.
Old Oct 3, 2016 | 09:26 PM
ubereal2's Avatar
ubereal2
Sounds like you should be fine then, and you are vary welcome
Unk Bob
jakeharp
Nov 26, 2016 11:16 PM
loseboltssinkships
Mar 1, 2011 11:15 PM
79F150400M
Jun 27, 2010 02:47 PM
SusanGriggs
Jun 16, 2007 05:13 PM
scottlane
13
Oct 26, 2005 07:13 PM
