Hello I have a 94 ford bronco 5.0 manual transmission truck I just recently purchased the previous owner said it just need a new starter, so after I installed a new one and the starter will not disengage it stays on so I had to get it wich he lived thankfully, after I got I installed anew starter selonoid, on the firewall still does it so I returned the starter and tried a new one, still will not stop Running so I put in a new ignition switch. And low and behold it still will not stop the starter! I’m at a loss anybody know what could be the problem??? Thanks- Tim
First things first with a starter. Make sure that you have a starter that's for a manual transmission. There's a difference between the manual and automatic starters, and getting the wrong one can cause problems.
Lastly, please reread your posts and fix the mistakes that "autocorrect" looks to have put in place. A few of your sentences are unclear as to what you're saying, which makes it hard to figure out what you have and haven't done.
