Starter Problem
Old May 1, 2004 | 08:45 PM
CINCYTREE's Avatar
CINCYTREE
Starter Problem
95 F-150 Starter Problem, Have Replaced Starter And Selenoid Switch And Still Getting Loud Clicking At Starter. Pulled New Starter And Bench Tested Ok. Where Do I Go Now? Thanks In Advance. Mjm
Old May 1, 2004 | 08:49 PM
CINCYTREE's Avatar
CINCYTREE
Dont Know Why
Old May 1, 2004 | 09:07 PM
welove03's Avatar
welove03
We are having the same issue. . .any answers yet?
Old May 1, 2004 | 09:09 PM
CINCYTREE's Avatar
CINCYTREE
No, Hope Some Has Tip
Old May 2, 2004 | 12:02 AM
Slade901's Avatar
Slade901
I would remove and clean all the heavy gauge wire cables in the battery, starter and ground and replace them if some shows sign of deterioration and if not just clean the contact ends and connect them back and tighten them good.
Make sure battery is fully charged. Failing battery would show 12 volts just like a new battery but it does not have the large AMPs required to turn over an engine.
Old May 2, 2004 | 09:05 AM
CINCYTREE's Avatar
CINCYTREE
Starter Problem
Have Done All That, Even Hooked Up Commercical Charger When Trying To Start And Still Get Loud Clicking At Starter
Old May 2, 2004 | 10:19 AM
Fordtech1's Avatar
Fordtech1
Engine locked up? Good engine ground? There are two power wires to starter, both powered in crank position? Voltage drop? What is the voltage on both wires at crank?
Old May 2, 2004 | 11:10 AM
CINCYTREE's Avatar
CINCYTREE
Starter Problem
Manual Tranny, Jump Start By Pushing Works Fine But, I Will Take Readings At Crank.
Old May 2, 2004 | 11:19 AM
Fordtech1's Avatar
Fordtech1
Good, at least it's not an engine concern. Should be an easy fix.
