stutter and shifting problem
Old Apr 19, 2019 | 03:14 PM
Gary Brewer's Avatar
Gary Brewer
Angry stutter and shifting problem
my 94 f150 with 5.0 starts fine but on road it will bog down and not take gas then if you manually put shifter down in 2nd gear it will take gas fine but when you let off gas and put back up in drive it shifts out too fast into over drive and will not take gas. on freeway it will be running fine at 65 to 70 and then just bog down like it is flooding or not getting fire right then eventually it will pick back up and go again. any suggestions on the cause from anyone would be much appreciated. and is the shifting controlled by a sensor . thanks.
Old Apr 19, 2019 | 04:14 PM
midwestbird's Avatar
midwestbird
Originally Posted by Gary Brewer
... and will not take gas.
What do you mean by that?
Old Apr 19, 2019 | 06:32 PM
torq'ta 5 8's Avatar
torq'ta 5 8
can you pull codes, (e.g. code reader or paperclip and check engine light flash), even if check engine light isn't on could still have stored codes, does check engine light flash or come on while driving and symptom shows up? f you dont have code reader, vjsimone posted link below to help get codes
try to run the KOEO & KOER Self-Test; https://www.scribd.com/doc/34996350/...-and-Procedure
no_exit
Mar 7, 2011 07:25 AM
jbway2cool
Jan 2, 2010 12:45 AM
Triple_E_Farms
1978 - 1996 Big Bronco
Mar 4, 2007 02:09 PM
VR666
Jul 26, 2004 10:10 PM
