Is a track bar relocation bracket necessary?
Old May 12, 2022 | 10:33 PM
obiwan kenobi's Avatar
obiwan kenobi
My F250 had a leveling kit when I bought it and I was convinced I needed a drop bracket. Bought it and installed it, had the alignment done and it drove worse than without the drop bracket. It wandered on the freeway and had significant bump steer, took that bracket off tonight, cenetered the steering wheel and it drives like it used to.
My driveability issues were likely related to the track arm and drag link not being on the same plane as mentioned above.
Old May 12, 2022 | 11:17 PM
Bitpilot77's Avatar
Bitpilot77
Originally Posted by obiwan kenobi
My F250 had a leveling kit when I bought it and I was convinced I needed a drop bracket. Bought it and installed it, had the alignment done and it drove worse than without the drop bracket. It wandered on the freeway and had segnificant bump steer, took that bracket off tonight, cenetered the steering wheel and it drives like it used to.
im considering going back to factory bracket as i just ordered adj track bar
Old May 13, 2022 | 08:24 AM
speakerfritz's Avatar
speakerfritz
problems with trackball relocation brackets could be due to the wrong size bracket. if you do a 2" lift and put in a 3" - 6" relocation bracket you will have problems.
best bet is and adjustable track bar replacement.
Old May 13, 2022 | 08:29 AM
Rob89's Avatar
Rob89
I think 1.5” is about the limit to not do an adjustable track bar or a drop bracket.
Old May 13, 2022 | 09:12 AM
Bitpilot77's Avatar
Bitpilot77
It's a 2.5 kit .... I actually bought the full kit again as it came with the TB relocation bracket all for 300$
Old May 13, 2022 | 09:58 AM
speakerfritz
understood
i bought a full kit recently for a 2.5 lift and got a relocation bracket for a 3” to 6” lift.
check the bracket part number to make sure you do not have too much correction.
Old May 13, 2022 | 10:13 AM
Bitpilot77's Avatar
Bitpilot77
understood
ahh I see what's pn on yours ? mines installed already
Old May 13, 2022 | 10:24 AM
speakerfritz
mine is installed.
The bracket that came with the kit was 67-2538 and it turns out that bracket is there de facto bracket for all their kits.
i would up taking it off and using a bracket that had numerous bolt hole options for the track bar depending on the lift.
the 67-2538 is supposed to be a 2.5 - 3.5 lift relocation bracket.
rpenterics
22
Apr 28, 2014 07:25 AM
Yahiko
Jul 11, 2012 03:58 PM
acf6
Dec 27, 2011 02:08 PM
jaye
Mar 3, 2008 06:29 PM
Robert6401
Aug 27, 2005 03:54 AM
