Sponsored by: Real Truck
Adjustable track bar for 2.5" level?
Old Aug 23, 2005 | 08:38 AM
Robert6401's Avatar
Robert6401
Do I need an adjustable track bar for my truck when I buy the levelling kit? Does it matter which kit I go with? Honestly, I'm not even sure what the adjustable track bar does, so feel free to educate me. Thanks.
Bob
Old Aug 23, 2005 | 08:50 AM
steeda007's Avatar
steeda007
I just put a Tuff country 2.5" leveling kit on my '99 CC PSD. The kit comes with a new track bar bracket that mounts to the drivers side frame and cross member. This new bracket has some adjustment possible, maybe an inch or so. Basically, the bar is what you use to center the axle under the truck. When you lift, if nothing else is changed, the axle will be too far towards the passenger side. I ended up drilling a new hole on the lower mount point of the bar to move it about 3/4" towards the passenger side, then the adjustable bracket ended up in the center if it's travel. Everything is perfect now...
Don
Old Aug 24, 2005 | 10:19 PM
Antelope V-10's Avatar
Antelope V-10
For what it's worth, I had the installer put a Fabtech Adjustable Trac Bar when installing my Rancho 2.5" springs. He said the adjustable trac bar made installation much easier. I felt better also knowing the front end isn't being pulled over from one side or the other.
Old Aug 24, 2005 | 10:24 PM
BFR250SD's Avatar
BFR250SD
Here's my .02
2.5"s is well within the normal droop for the suspension. I wouldn't spend the money on the adjustable track bar unless you're going higher than that. Even on my 6", I only have the rack bar bracket and it's just fine.
Old Aug 24, 2005 | 11:28 PM
Antelope V-10
The Rancho springs don't come with any kind of drop bracket. Like I said, it is nice knowing my front end is dead center and not being pulled left or right because of a short trac bar.
Old Aug 24, 2005 | 11:37 PM
1MUTCJ7's Avatar
1MUTCJ7
It will definitely make the installation much easier. I couldn't believe how far off alignment mine was after installing the DR 2" mini spring pack.
I feel the same way as Antelope-V10, I didn't like the idea of having lateral tension in the springs with the short trac bar. So I went with the DR adjustable trac bar and everything is centered now.
Old Aug 25, 2005 | 07:22 AM
Robert6401's Avatar
Robert6401
How much did you guys pay for your adjustable track bars??
Old Aug 25, 2005 | 07:41 AM
Antelope V-10
I think the Fabtech was in the $120-$140 range. Summit had them too.
Old Aug 25, 2005 | 07:51 AM
Robert6401's Avatar
Robert6401
What makes the axle become off-center when you increase the height? I could understand it moving fore and aft, but left and right makes no sense to me. I know Im pretty ignorant about this stuff though, which is why I love FTE so much
Old Aug 25, 2005 | 08:00 AM
BFR250SD's Avatar
BFR250SD
Think of it like a triangle using the axle, leaf spings, track bar.
The axle goes horizontal, the leaf spring is the vertical, that leaves the track bar as the diagonal part. If I make the vertical line longer, what does that do to the horizontal line if the diagonal one doesn't get longer or short. Keep in mind the axle stays on a horizontal plane. It moves it over.
The track bar centers the axle from left to right and an increase in height changes the location of the axle from left to right.
Confused.
Old Aug 25, 2005 | 08:04 AM
Robert6401's Avatar
Robert6401
Actually, that helped quite a bit, thanks, I do understand it now.
Old Aug 25, 2005 | 08:06 AM
Robert6401's Avatar
Robert6401
Summitt has the Fabtech on Clearance today for $98.50, should I jump all over that? Hell, I dont even have the levelling kit yet, but this seems like something that would be good to have at a good price for when I do get the kit.
Old Aug 25, 2005 | 08:14 AM
BFR250SD's Avatar
BFR250SD
Here is a little visual of it. You can see as you lenghten the track bar it brings everything back into alignment.
Old Aug 25, 2005 | 08:17 AM
Robert6401's Avatar
Robert6401
You are the man BFR250SD! BTW, that is one kick @$$ ride you got man, probably one of the more capable SDs I've ever seen with the lockers and the low gears. Looks like you did it right. Thanks again for the help.
Old Aug 25, 2005 | 08:21 AM
BFR250SD's Avatar
BFR250SD
Not a problem. Thanks for the compliments.
