Alternative ICP sensor
Old Apr 19, 2019 | 06:13 AM
Cartel's Avatar
Cartel
Smile Alternative ICP sensor
Does anyone have the specs on the ICP voltages and pressures?
These sensors seem pretty cheap looking for the price.
Is it possible to sub it for a more reliable scientific or industrial part?
Like this for example only.
TDL35 Series Pressure Transducer 0-3000 psi - Pressure Transducers, Pressure Sensors: Transducers Direct
Old Apr 19, 2019 | 07:09 AM
Walleye Hunter's Avatar
Walleye Hunter
I seem to recall someone posting a list of sensors and their voltages. I like the thought of that but can't help, I looked and don't have that chart.
Old Apr 19, 2019 | 06:02 PM
dmd's Avatar
dmd
Mine lasted 19 years.. That was pretty reliable I think.
Old Apr 19, 2019 | 11:25 PM
kbeefy's Avatar
kbeefy
Seems reasonable.
Why wouldn't you just buy the good stuff?
It's not like these are ****box Hondas.
And the right parts don't cost that much.
Old Apr 20, 2019 | 01:20 AM
Cartel's Avatar
Cartel
I've been looking at the zibbix brand ones.
Old Apr 20, 2019 | 11:28 AM
Walleye Hunter
IIRC those ICP sensors are downright pricey and if there was a reliable and economical substitute I'd go that route.
Old Apr 20, 2019 | 12:24 PM
pirate4x4_camo's Avatar
pirate4x4_camo
I have a $10 Chicom in my glovebox for a spare but would never run a non Motorcraft unit.
That Zibbix marketing want you to believe the seal is the issue you need to be concerned about but that isn’t even close to the issue.
the actual ceramic chip that turns pressure into a voltage is itself a dumb chip and all the Icp sensors would have more or less the same chip, where the magic happens in the Motorcraft is the propriety chip that is programmed to compensate for temperature differentials to give accurate and precise readings for the intended purpose, any non Motorcraft ICP is going to have a generic chip and no interpreting chip. It will work as much as it will run but doubtful it would be able to run as well as a Motorcraft chipset.
Old Apr 20, 2019 | 12:30 PM
pirate4x4_camo
Dang it, Can’t find the pics on my phone of the insides of the Motorcraft unit I cut open but I have posted them before if you search.
Old Apr 21, 2019 | 11:08 AM
RigCity's Avatar
RigCity
Cheaper sensors usually have less copper shielding. My truck used to hiccup putting it lightly around radio towers. Sometimes it would not even turn back on without excessive cranking in the middle of a highway with cars almost hitting you. At 125/sensor that’s cheap enough for me. Just dropped 460 on my Yamaha o2 sensor that was real fun.....considering they used to be 200 or so but I’m now ready to head into the rough seas with confidence my #1 cylinder is not leaning out under demand!
Old Apr 21, 2019 | 11:41 AM
patineto's Avatar
patineto
subscribe..
Cell's
Apr 3, 2022 10:56 PM
MetalRider
2009 - 2014 F150
Aug 30, 2018 01:15 AM
Talyn
Jan 9, 2016 10:24 AM
Russian
Bronco II
Jun 28, 2010 06:56 AM
FatBrian
18
Aug 16, 2007 08:11 PM
