?swap pcm
Old Apr 21, 2019 | 02:36 PM
tommyl's Avatar
tommyl
?swap pcm
Can I swap late '99 pcm to my '03. Trying to run down code p0344.
Old Apr 21, 2019 | 02:48 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Have you already ohm and visually inspected the wires ? Seems highly unlikely it would be a PCM issue and if it was the PCM it wouldn’t be that code....it’s the wires, connectors, or sensor
Old Apr 21, 2019 | 02:55 PM
tommyl's Avatar
tommyl
replaced the sensor with oem. no change. ohmed wires, limited electrical knowledge here. thinking short in wiring, troubleshoot guide says it could be a pcm.
Old Apr 21, 2019 | 03:06 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
It'll physically run and drive. No charging system will be your main concern though.
Old Apr 21, 2019 | 03:36 PM
tommyl's Avatar
tommyl
it will start and run, but. it may die and start backup 2-3 times before you can get up to speed. seems like if i am heavy on the throttle it dies, go easy and it picks up speed.
imjwm
15
Aug 5, 2015 05:15 PM
dgpach
1997 - 2003 F150
Mar 10, 2010 11:02 AM
cleatus12r
Aug 10, 2009 03:30 PM
aklim
Apr 29, 2006 04:10 PM
