Sponsored by: Real Truck
Radius Arm Bushings
Old Apr 17, 2019 | 06:01 PM
bunklash's Avatar
bunklash
Radius Arm Bushings
This refers to my signature vehicle. After replacing tires (from Michelins to Firestone R speed rating on the rear, and Maverick Q speed rating on the front), I experienced rear end sway when the steering is jerked slightly. Moving the Firestones to the front helped some. Then my highly trusted tire guy replaced the Mavericks with General SR R on the rear. In the meantime, he got under the truck and had a helper steer the front wheels back and forth. He said the radius arm bushings have deteriorated, and it will contribute to the rear end sway. He also cited the bushings of the two arms that run from the front axle assy on each side about 3-4 feet toward the rear of the vehicle. I forget what he called them.
Does anybody out there have experience/knowledge about these components? Is it true worn bushings could contribute to the back sway problem. I plan on keeping the truck 'till I can't drive anymore, and do want it to stay in good condition. I'd appreciate any help. Especially if anybody can cite any videos or articles to educate me.
Thanks in advance!
Old Apr 17, 2019 | 08:01 PM
Just Strokin's Avatar
Just Strokin
You should be able to rent a tool similar to this one for the upper control arms to replace the bushings in the radius arm
Radius arm bushings.
https://www.ebay.com/itm/NEW-Front-R...EAAOSwhBtcpXX0
Or radius arm, right side... (other side should be similar price)
https://www.ebay.com/itm/99-17-F-250...wAAOSwVAtcQMhS
Old Apr 17, 2019 | 08:12 PM
Just Strokin
Ford workshop DVD says to remove the spring....then remove the radius arm....This is from the 2015 Ford Workshop DVD....Appears the same radius arm is used form 1999 thru 2017...
Old Apr 17, 2019 | 09:38 PM
bunklash's Avatar
bunklash
Larry,
Just the kind of info I was looking for. Thank you muchly!
Old Apr 22, 2019 | 12:30 PM
bunklash's Avatar
bunklash
Radius arm bushings
Should I drop the whole front end, or do as easily in place? Again, thanks.
Old Apr 22, 2019 | 04:44 PM
Just Strokin
I would do one side at a time and not drop the front end.
Old Apr 22, 2019 | 05:07 PM
bunklash's Avatar
bunklash
And what are the two similar components that run left to right from each wheel. I thought they were the radius arms, and the ones in the illustrations you sent me were formerly called the I-beams? I believe I need to change the bushings on all four of them.
Old Apr 23, 2019 | 07:10 PM
SuperDutyScaler's Avatar
SuperDutyScaler
Your talking about the twin i-beam front axle? There one bushing at each end, they are know to go bad on ALL of fords trucks that use them. They can be a real pain in the rear to replace sometimes
Old Apr 25, 2019 | 12:46 PM
bunklash's Avatar
bunklash
I think so, but I'm not sure. I'll try to post a pic later.
I thought I set this thread up for instant notification, don't mean for the delay in replying. I'll try to fix that too. I REALLY appreciate your help.
Old Apr 25, 2019 | 04:07 PM
U9000's Avatar
U9000
As clarification, 2004 and earlier did NOT have radius arms on the 4WD's, they had leaf springs (in the Super Duty's). 2005 and up had the radius arms (in the Super Duty's).
Old Apr 25, 2019 | 07:59 PM
F250 Hauler's Avatar
F250 Hauler
I was able to find this part number for the Ibeam bushing for a 2003 F250, 2 wheel drive, MAS AB85049, you will need 2 of these. I will be replacing these myself along with the Balljoints, radius arm bushings.
Old Apr 25, 2019 | 08:00 PM
bunklash's Avatar
bunklash
Mine is a 2002 Two wheel drive. It has coil springs. I'm trying to upload a photo, but lost in the technology of it all. I'll keep trying.
Ah, finally! Here's a photo taken from under the front bumper aiming toward the rear of the truck. https://www.ford-trucks.com/g/album/13630835. At the bottom left in the photo is the arm that runs perpendicular to the crossing I beams, running toward the rear of the truck. Hope this makes it clearer.
Old Apr 25, 2019 | 08:06 PM
bunklash's Avatar
bunklash
Old Apr 25, 2019 | 08:51 PM
F250 Hauler
The MAS AB85049 should be the correct part number, although it doesn't appear to be available at amazon, (where I got the set I will be using) it can be found elsewhere. You can also google the part number and click the "Image" tab to get a picture of the actual part.
coolfeet
Mar 12, 2016 10:19 AM
Roller150
13
Sep 1, 2010 08:17 AM
BAJI26
Jun 23, 2009 06:52 AM
geowing
Oct 9, 2004 01:55 AM
BuyaFord?
Aerostar
17
Sep 24, 2003 02:37 PM
