Oil Consumption
Old Oct 26, 2019 | 11:27 PM
  #46
Jake Allison's Avatar
Jake Allison
Originally Posted by 867.309
Did you do the oil cap upside-down blow-by test?
It seems to pass that test fine. Definitely has some steam coming out the oil fill when I cold start it but I dont think it’s anymore than normal.
Old Oct 27, 2019 | 12:57 PM
  #47
BBslider001's Avatar
BBslider001
Originally Posted by Jake Allison
I’ve now replaced the turbo bearing carrier, put another fresh set of bushings in, new rear main while installing dual disk, went to e-fuel, and upgraded injectors without seeing any improvements in the oil loss. One major thing to note, when I had the oil cooler off I found two pieces of gravel that were just large enough that they wouldn’t fit through the passages. I found one more with the oil pan off in the pickup screen. Not sure what happened to it in it’s past life that would’ve introduced rocks into the oil but that’s kinda just how my luck goes. I’ll probably do another compression test to confirm after running it for a while but I’m sure it’s time to start looking into a full rebuild.
Man I hate to hear this. FWIW, with my first oil cooler rebuild on my '97 dually had those little pebbles in the passages. I did not have oil consumption and i am not sure what they were from, but I don't think that is your issue. JMO....I am not sure if they were from ill-maintained coolant or what, but I cleaned them out with a coat hanger and didn't think about it again.
Originally Posted by z31freakify
With those compression #'s I wouldn't worry about piston rings but I would worry about valve guides/seals, if it was trully a low mileage engine that only means the engine wasn't run to often so either the seal are bad or the valve guides themselves wore out with all those dry starts.
I tend to agree here Adam. You know I have been down this road. It's where I got my "well oiled machine" theory that I firmly adhere to. I have seen it time and time again.
Originally Posted by oldbird1965
So Adam, are you saying that only running my old Mule 500-1000 miles a year where it sits all winter and summer is going to ruin the motor?
I do not think that is what Adam is saying here Glenn. See above.
I wouldn't generalize its just my opinion, but think about its the last place the oil hits in the valve terrain.
Again, I do think there is some merit here with this information.
Old Oct 27, 2019 | 03:25 PM
  #48
Jake Allison
I really hope you guy’s are right. It makes sense cause even in the relatively short time I’ve owned it there’s been a ton of what would be dry starts on it cause I’m just not home enough. Rarely does it ever get drove even two days in a row. Do I need to do Comp 910’s while I’m there?
Old Oct 27, 2019 | 03:33 PM
  #49
Hit Man X's Avatar
Hit Man X
910s make a real nice difference in valve train stability. Plus, it is a well known fact OE springs are very soft from the factory. Spend the time to shim them correctly while in there, No8 will test your patience.
I did Smith Bros rods while in there too
My stem seals came from Riffraff, I think I bought Alliant/Navistar. They were green, old were black.
If you still have oil loss, Supertech it up for $10/gal. I do...Byron knows this.
Old Oct 27, 2019 | 07:27 PM
  #50
PSU4ME's Avatar
PSU4ME
If you’re in there you might as well do the seal, 910s, keepers and at a minimum check your rods straightness and replace any busted oil deflectors etc.
I did 910s, seals and the smith bro rods like HMX stated. Rods are probably overkill but since I was burning money I threw 3 more notes on the fire.
Old Oct 27, 2019 | 08:07 PM
  #51
Hit Man X's Avatar
Hit Man X
Thumbs up
Exactly my thoughts!
Old Oct 27, 2019 | 09:40 PM
  #52
Jake Allison
My patience should be up to par by now with everything I’ve been through on this thing
I wish I would’ve switched to something cheaper a long time ago. Could of single handedly kept rotella in business.
If they’re all straight I’m leaving them alone! Lol already went way overboard on everything else and I’m ready for a break.. on this project anyways 😅
Old Oct 27, 2019 | 11:39 PM
  #53
BBslider001
Go Supertech or Tractor Supply whether or not you are burning oil. You will not be disappointed.
Old Nov 23, 2019 | 09:29 PM
  #54
Jake Allison
Well a few weeks back I found four bad valve seals. One of them was completely split so I replaced them all and shimmed up some 910’s. Found that probably more than half of the pushrods had at least a little wobble in them. Some were worse than others but I buttoned it back up to make the trip back home thinking the oil disappearing act would be up. Once again, I thought wrong. It seems like it could be slightly better but still going through a gallon just to make it back. Way excessive
Old Nov 23, 2019 | 09:42 PM
  #55
z31freakify's Avatar
z31freakify
Time to remove the injectors and check for damaged O rings.
Old Nov 24, 2019 | 06:07 AM
  #56
Jake Allison
I recently put 175cc injectors from Swamps in it.
Old Nov 24, 2019 | 08:37 AM
  #57
z31freakify
Doesn't mean the O rings didn't get rolled or damaged when installed.
Old Nov 24, 2019 | 08:58 AM
  #58
BBslider001
What Adam said. Have you checked your fuel filter for fuel color?
Old Nov 24, 2019 | 10:46 AM
  #59
Jake Allison
Do I really need to pull them three times? I don’t have the stock fuel filter anymore so I’ll just have to drain some fuel out of the tank.
Old Nov 24, 2019 | 10:53 AM
  #60
867.309's Avatar
867.309
You may be able to route your fuel return into a catch can to check it.
