1” Wheel Spacers
Old Apr 17, 2019 | 11:23 AM
Motown82's Avatar
Motown82
1” Wheel Spacers
So I would like to get the tires to stick out a but more but have no experience with wheel spacers. I know a lot of people say to stay away from them, but I hear that more about the 2” spacers.
Whats everyones thoughts on just going with a 1” spacer? Any advantages of going with a 1” over a 2”?
Old Apr 17, 2019 | 03:14 PM
potato potato's Avatar
potato potato
I wouldn't recommend wheel spacers that were not hub centric.
With that said, I believe the narrowest hub centric spacer available is 2in because it has to cover the full lug length.
Old Apr 17, 2019 | 06:35 PM
INFAMOUS FAME's Avatar
INFAMOUS FAME
I would stay away from spacers with these heavy trucks no need to compromise you or anyone on the roads safety.
Old Apr 17, 2019 | 07:26 PM
honda250xtitan's Avatar
honda250xtitan
Bora aka Motorsport-tech sells bulletproof bolt on spacers.
Old Apr 17, 2019 | 07:57 PM
h20camper's Avatar
h20camper
Interesting. Thanks. They don't state advantages/disadvantages of steel to aluminum.
Wheel Adapters, Wheel Spacers, Hub Rings for your car! | Motorsport Tech
Old Apr 17, 2019 | 08:04 PM
JHForman812's Avatar
JHForman812
I don’t trust wheel spacers one bit!! Seems sketch AF to me but it’s your truck your choice
Old Apr 17, 2019 | 09:10 PM
Sonny Crockett's Avatar
Sonny Crockett
I'd get new wheels before I got spacers. I hear the Boras are the only way to go if you do get spacers.
Old Apr 17, 2019 | 09:57 PM
RainDesert's Avatar
RainDesert
The biggest problem going with anything less than a 2" spacer is you will have to cut your factory wheel studs. There's no way I would do that. To add a little stance to your truck put your money into +18/20mm offset aftermarket wheels.
Old Apr 18, 2019 | 05:10 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Originally Posted by h20camper
Aluminum for show. Steel for work.
I would have no problem running their steel spacers on my truck. When installed and torqued properly (and checked on a regular basis...this is something people NEVER do which helps lead to their negative connotation), spacers can be very functional and reliable.
1" spacers will require you to cut your stock studs shorter. Something I would NOT do. 2" spacers just seem excessive.
And remember....spacers play hell with your wheel bearings leading to a shorter life due to the extra leverage.
Old Apr 18, 2019 | 05:13 AM
Jointasset's Avatar
Jointasset
I’ve had 2”spacers on my Excursion for 5 years/70k miles w no issues. Mine are steel and definitely make sure you buy hub-centric
CamoF-250
May 4, 2019 11:48 AM
JamesTapley
Dec 6, 2017 10:30 PM
thowle
May 17, 2015 11:40 PM
Flying_Dutchman
Feb 10, 2009 06:03 PM
4wheelfurry
Mar 14, 2008 04:51 PM
