Sponsored by: Real Truck
2001 F 350 Down Shift Problems
Old Apr 15, 2019 | 11:05 PM
larryhag's Avatar
larryhag
My F350 will not down shift out of lock up converter when you touch the brake, it will however down shift when you are climbing a grade an push the accelerator but wants to slip momentarily before the trans grabs or the clutches engage.
Old Apr 15, 2019 | 11:54 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If you're more than about 10% throttle it won't unlock when you press the brake pedal. It also won't unlock if the brake lights are not working.
Old Apr 17, 2019 | 08:04 AM
larryhag's Avatar
larryhag
I put it on the scanner an It shows when the brake switch is engaged but trans still will not come out of lock up an this is at no throttle
st8yd
1997 - 2003 F150
15
Apr 18, 2013 07:04 AM
Dmntxn77
Feb 25, 2012 09:06 PM
Gwilkrrs
Aug 15, 2011 12:56 PM
riverratba
2004 - 2008 F150
Jul 20, 2011 07:19 AM
1979F1504X4
1997 - 2003 F150
Aug 27, 2004 09:44 PM
