Sponsored by: Real Truck
TPMS Issues
Old Apr 15, 2019 | 04:07 PM
rtf505's Avatar
rtf505
TPMS Issues
TPMS Issues
Post by rtf505 » Mon Apr 15, 2019 4:06 pm
I've got a TPMS that comes up in the Message Center of my 14 F250 4WD Crew. When I mash the reset on the steering wheel, the message goes away, but the low tire indicator in the lower right corner of the instrument panel stays lit. Everytime I start up, I have to reset to get it out of the message center. I have reset it multiple times through FORScan, but when I cycle the ignition, it finds the same DTC.
I'm open for any and all suggestions and yes, I've corrected all my tire pressures to what the door panel recommends. . .
Old Apr 15, 2019 | 05:00 PM
seville009's Avatar
seville009
How old are the sensor valves in your tires? They can/do go bad. Looks like that is what your message is telling you. Wonder if maybe a bad valve is triggering the message and that’s why you can’t get rid of it
another thing to try is put more air in - if you’re at 55 psi, put in 70 (assuming you have load E tires) and drive it for a few days and see if it resets
Old Apr 15, 2019 | 05:43 PM
rtf505's Avatar
rtf505
the sensors are original to the truck, so 5 years old now. I’ve always had some TPMS gremlins, so much so that checking the air pressure wasn’t my first thought. I’ll give it a few days and see what happens, new tires are probably on the horizon anyway...
Old Apr 15, 2019 | 07:16 PM
Qwazert's Avatar
Qwazert
Did you check your spare as well?
My first experience with this TPMS thing started last year with my daughter's Honda Ridgeline. From what I've researched, the batteries in these things do die eventually, so you have to replace them.
Personally, I hate them...stuff like this just adds another layer of laziness when it comes to vehicle maintenance. Whatever happened to a 10-point inspection? Are people *really* so lazy/clueless that they need an alarm to tell them that their tires are low?
Luckily when have oil gauges so we don't have to check that either, eh?
</old guy rant over>
Old Apr 15, 2019 | 07:57 PM
vik4310's Avatar
vik4310
4wd Low
if you have forscan go in and check the setpoint, I lowered mine to 65 for front and rear. I think my factory settings where 70 front and 80 rear.
Old Apr 15, 2019 | 08:04 PM
rtf505's Avatar
rtf505
Set points are 75 front and 80 rear, which is what they have in them. I didn’t think about the spare having a sensor as well. That might explain some of my “gremlins”. I’ll check it tomorrow...
Old Apr 16, 2019 | 03:06 AM
seville009's Avatar
seville009
i agree with you. I don’t put the tpms valves in any new tires. Wife had low profile tires on a Taurus; drove around for a day with a flat tire - ignored the tpms light. Looked low to my eyes (just a slight bulge) so I checked it - was showing 9 psi.
Old Apr 16, 2019 | 08:18 AM
saratoga2011's Avatar
saratoga2011
The TPMS sensors in my 2013 died at 5 years and I started getting all kinds of TPMS FAULT messages with the orange tire pressure light. I have put tires on it previously but I did not have them replace the sensors at the same time.
3 of the 4 would not respond when the tire shop held their TPMS scan tool up to the wheels. They're sealed but are powered by the same 2032 button cell battery in your key fob so they will definitely die.
fordman19762003
Oct 31, 2013 04:58 AM
MikeMcCasland
Oct 1, 2009 05:46 PM
87wreckerman
Offroad & 4x4
38
Apr 4, 2008 09:45 PM
Xyzzy
26
Jun 27, 2007 08:53 PM
Aggie10
Dec 6, 2006 06:52 PM
