High EBP after full delete and new exhaust on 6.4
I have a complete delete but my ebp is high. 55@ idle, but goes up as high as 175psi when I get in the pedal. Boost is normal, temps are normal, everything normal but ebp. New sensor, no change. The only thing I can think of is the block of plate on the EGR cooler pipe is not letting exhaust gas flow freely anymore and it's getting a false reading. I am running an Sct Livewire tuner. I also put new 4" straight Magnaflo exhaust on it. Truck runs great, but shifts funny if I get on it. Got a 5 mpg increase, no power shortage. Anyone else having this problem,?
The pcm/ecm needs a reed on the sensor to insure your not out of range. Look around the new pipe that bypassed the EGR and see if the pigtail is hanging empty. You should have two pigtails. One is going to be a plug (should be empty), the other will house the sensor. If the sensor is removed, I'm thinking the computer is saying wtf.
Look down this forum a few threads for a picture that was posted about "loose cables" and you can get a great view of what you should be seeing.
Denny (I'll see if I'm sober enough to do that for you)
I took the sensor of the vertical EGR cooler and plugged back in, no change. I talked to the guy that sold me the tunes and he gets them from Gearheads, he got in touch with them and they say it's not a problem. I'm calling BS on that one but I really don't know, could be. 🤔 I'm going to attach a pic of mine.
Two plugs from EGR and one from EGR cooler
norvillebob
11-29-2011 08:49 AM
Silentst2000
08-01-2005 04:44 AM
