Transit Connect 2010+ Ford Transit Connect
Engine management light not coming on
Old Apr 14, 2019 | 11:39 AM
RiverTowy's Avatar
RiverTowy
2006 Connect T220L SWB 1.8 Diesel. No engine management light on when key turned in ignition on starting. It doesn't come on when there is a fault either, e.g. cooland sensor failure.
I have run the cluster self test and the EML does illuninate, so the LED is good. All other dials/guages/LEDS work fine.
Old Apr 15, 2019 | 02:17 AM
RiverTowy's Avatar
RiverTowy
It has been suggested on another forum, that the problem is probably a processor communication to the CEL fault/malfunction.
I cannot afford to pay £150+ to take it to a Ford garage to be put on a diagnostic tool.
How would I go about getting this investigated?
Old Apr 15, 2019 | 03:12 AM
seville009's Avatar
seville009
Sometimes you simply have to spend money if you need to get something done
on the other hand, if you don’t have any actual problems other than the light itself, just leave it as is
cody pendant
Large Truck
Feb 28, 2013 11:54 PM
nightowl263
Dec 20, 2011 10:45 PM
BlueOvalDude
1983 - 2012 Ranger & B-Series
Jul 14, 2011 02:41 PM
John with beastly 302
Aug 24, 2006 11:13 PM
nightshifter
Aerostar
Jul 31, 2004 03:24 PM
