Transit Connect 2010+ Ford Transit Connect
Engine management light not coming on
Old 04-14-2019, 11:39 AM
RiverTowy's Avatar
RiverTowy
RiverTowy is offline
2006 Connect T220L SWB 1.8 Diesel. No engine management light on when key turned in ignition on starting. It doesn't come on when there is a fault either, e.g. cooland sensor failure.
I have run the cluster self test and the EML does illuninate, so the LED is good. All other dials/guages/LEDS work fine.
Old 04-15-2019, 02:17 AM
RiverTowy's Avatar
RiverTowy
It has been suggested on another forum, that the problem is probably a processor communication to the CEL fault/malfunction.
I cannot afford to pay £150+ to take it to a Ford garage to be put on a diagnostic tool.
How would I go about getting this investigated?
Old 04-15-2019, 03:12 AM
seville009's Avatar
seville009
seville009 is offline
Sometimes you simply have to spend money if you need to get something done
on the other hand, if you don’t have any actual problems other than the light itself, just leave it as is
cody pendant
Large Truck
02-28-2013 11:54 PM
nightowl263
12-20-2011 10:45 PM
BlueOvalDude
1983 - 2012 Ranger & B-Series
07-14-2011 02:41 PM
John with beastly 302
08-24-2006 11:13 PM
nightshifter
Aerostar
07-31-2004 03:24 PM
Quick Reply: Engine management light not coming on
