2016 back up camera "unavailable"?
Old Apr 12, 2019 | 02:36 PM
lsukevinc's Avatar
lsukevinc
the past few weeks almost every time i shift my truck into reverse, the screen turns blue and an error message pops up stating "camera unavailable" i tried to clean the connection between the camera and the wiring harness and it is still doing it. It seems to be the camera. Has anyone else had this issue? any other tricks to try to get it working again or only option is to replace the camera?
Old Apr 12, 2019 | 02:52 PM
seville009's Avatar
seville009
https://www.ford-trucks.com/forums/1...available.html
Old Apr 12, 2019 | 02:58 PM
jr105's Avatar
jr105
I've had this happen intermittently when it's extremely cold. I had the dealer look at it and they just said they couldn't duplicate the problem.
Old Apr 12, 2019 | 09:52 PM
onug's Avatar
onug
When I’m President, there will be a law that requires dealerships to hand you a $20 bill before saying this.
Old Apr 15, 2019 | 07:06 AM
lsukevinc's Avatar
lsukevinc
i found a wiring diagram online and i will verify it is grounded and getting power. I did unplug it at the tailgate and the big connection near the spare and all pins seemed to be fine. i sprayed some wd 40 and connected everything back an it did not work. This morning on the way to work it was working....go figure.
Old Apr 15, 2019 | 08:02 AM
HiTechRedneck1's Avatar
HiTechRedneck1
Had the same issue and it was the tailgate connector. Used carb cleaner on the pins (WD40 is not the same) and then taped it good after I plugged it back in - no problems since for over a year.
Old Apr 15, 2019 | 08:49 AM
Robbgt's Avatar
Robbgt
Recommend this over WD-40 or carb cleaner. Can get at most parts stores.
Old Apr 29, 2019 | 02:10 PM
lsukevinc's Avatar
lsukevinc
i tried the QD electronic cleaner and it still does not work. i cleaned the connection at the camera and the harness under the truck near the left tail light. i guess i need to order the camera now.
flumpydog
Feb 19, 2022 06:06 PM
JMDawg
6.7L Power Stroke Diesel
Apr 18, 2017 03:13 PM
nesterhow
2009 - 2014 F150
Apr 13, 2017 05:57 AM
LSUtigers
1997 - 2003 F150
Mar 14, 2007 12:16 PM
LorenS
Oct 17, 2006 10:55 PM
