Sponsored by: Real Truck
Brake lights stuck on
Old Apr 11, 2019 | 07:00 PM
Snapon90's Avatar
Snapon90
Just had new hydro booster and reservoir put on. Noticed my brake lights were staying on constant. Replaced the relay switch on the brake pedal but they still are staying on and my auto start won’t start unless I unplug the relay switch. Any ideas?
Old Apr 11, 2019 | 11:21 PM
Colorado350's Avatar
Colorado350
Welcome to FTE.
It would help if you gave us year, engine etc...
Old Apr 12, 2019 | 02:55 AM
VanS,ak's Avatar
VanS,ak
The pedal isn't depressing the switch is it? Maybe they adjusted the pedal also and now it's making contact with the switch all the time?
Old Apr 12, 2019 | 07:03 AM
Snapon90's Avatar
Snapon90
Switch
I couldn’t see an adjustment for the pedal. The pedal is non stop contact to the switch. My brake rod didn’t adjust. And the pedal is squishy
Old Apr 12, 2019 | 11:42 AM
VanS,ak's Avatar
VanS,ak
sorry i was thinking of the older models i think. i just watched a video on a guy replacing a hydroboost and saw there is a retaining clip inside that presses a spring against the pedal rod. it looks like if the tabs were not bent right when reinstalling it could push the pedal rod in to far and not give you the slop that is needed to not depress the switch. check out the section that starts at 4m54sec,
. maybe you need to take it back to who installed it and have them fix it?
milkstake
Jan 29, 2019 12:42 PM
feth91
2004 - 2008 F150
Oct 16, 2011 07:36 AM
Wandering_Burr
Electrical Systems/Wiring
Jan 30, 2006 02:36 PM
coolcasper
1978 - 1996 Big Bronco
Jun 28, 2003 10:37 PM
cow_boy104
May 23, 2003 02:13 PM
