Removing tailgate
Old Apr 10, 2019 | 06:58 PM
Navistar86's Avatar
Navistar86
Removing tailgate
Is it difficult removing tailgate from 2019 f350 lariat? Cant find much on YouTube
Old Apr 10, 2019 | 08:12 PM
wrvond's Avatar
wrvond
No, it is not difficult. The steps are detailed in your owner’s manual. Around page 70 or so.
Old Apr 10, 2019 | 08:14 PM
Alaskan_Warbird's Avatar
Alaskan_Warbird
It's very easy. Easiest with 2 people. I remove mine many times in the summer for the TC.
Old Apr 10, 2019 | 08:37 PM
TCNashville's Avatar
TCNashville
Had mine off in about 10 minutes by myself and set it on 2 saw horses with towels on them. The aluminum tailgates are a lot lighter. Just lower the right side until you see where the gate "unlatches" from the post and pull it out. Be leery of the camera wiring.
Old Apr 10, 2019 | 08:39 PM
Carnac22's Avatar
Carnac22
Removing was easy, but I found some help to put it back on - mine is a Platinum with the step - a bit awkward to get lined-up by myself. I didn't want to damage it. Removal was very easy though.
Jim
Old Apr 10, 2019 | 08:56 PM
nuctrooper's Avatar
nuctrooper
Depends. Are you used to removing a pre-2017 tailgate? If not, it isn’t too bad. An extra pair of hands are important the first time. If you think it’s just like your 2003 tailgate (Like I was the first time) you may poop yourself the first time you pull it off by yourself.
Just sayin. It’s kinda heavy. And expensive.
Old Apr 10, 2019 | 09:00 PM
RCR70ss's Avatar
RCR70ss
Two Electrical connections on mine, (Drivers side under the bumper area) The 2 Dummy plugs for the open circuits were in the glove box if your leaving it off for a extended time...
Old Apr 10, 2019 | 09:01 PM
maxum96's Avatar
maxum96
Easy to take off. Do yourself a favor, get someone to help you. I took mine off by myself and almost dropped it. I couldn't have put it back on by myself.
Old Apr 10, 2019 | 10:30 PM
stufarmer's Avatar
stufarmer
Taking it off is the easy part. Putting it back on is a Bitch .. Defiantly a 2 man job. I have 2 Electrical Connections and the Shock to Re-Connect. Did I mention its a Bitch to put it back on ..
Old Apr 10, 2019 | 10:59 PM
77mmbass's Avatar
77mmbass
hmmmmmmmmmm......
looking to sneakily add a few tailgates to a collection......?
Hmmmmmmm.....
Old Apr 10, 2019 | 11:01 PM
Phx Raven's Avatar
Phx Raven
If you have the tailgate step a second person is a must as it’s a heavy pig. If not you can remove it yourself.
Old Apr 11, 2019 | 08:58 AM
bobv60's Avatar
bobv60
I remove mine often for a truck camper.
I bought a hydraulic table from Harbor Freight. That, with a 3"x4' piece of plywood and some blankets I can set the plywood and blankets just above the bumper. I could do it myself, but easier with two people.
This allows you to have a place to set the tailgate, and help support it., and not have to carry it. The table has wheels so easy to move around the tailgate to storage or back to the truck.
I have done my 2011 truck myself a few times witout the table, and dropped it once. With the step in the tailgate, it can be heavy.
If you have the powered tailgate you must open it before you remove the wires.
Old Apr 11, 2019 | 12:29 PM
maxum96's Avatar
maxum96
Yup, I got the factory tailgate step and that's part of the reason I almost dropped my tailgate when I took it off.
Old Apr 11, 2019 | 01:35 PM
Navistar86's Avatar
Navistar86
Great info guys. Thanks
coastaldc
Jan 18, 2017 10:39 PM
don123
Nov 30, 2016 06:53 AM
Tarmac
2004 - 2008 F150
Jul 20, 2008 04:57 PM
preyj
1997 - 2003 F150
Apr 2, 2007 07:37 PM
Dan S.
May 5, 2004 09:28 AM
